Welp it happened - 427ci lq9 ate it
#25
When mine had similiar symptoms was from trunion kit, but used stock bolts which bottom threaded hole out in the head thus not clamping rocker down tight enough. To naked eye everything looks kosher, and you can even get to tq to spec. Switched to comp bolts after fixed rocker worked like a champ (stock l92 except springs). Still ran a 12.0 on 7 cylindars in a tbss though. Sounded kind of like a misfire
