Welp it happened - 427ci lq9 ate it
#51
Well I've decided to pull the heads and send them to wcch for their stg 3 program.
I'll pull the lifters and inspect as well as pull the cam - if I see bearing wear I'll likely pull the engine for a refresh or a new block. Depending on what I see will determine next steps but I'm really hoping for minimal wear and just a new cam and lifters so the build can "live" haha
Be sure to show us some pics of those piston skirts.
#52
You are getting out of the street driven vehicle area with that stuff. Shorter pistons that are more prone to rocking and shorter rods that put even more thrust on the face of the pistons are for the 1/4 mile crowd only. Or anyone else who is going to rebuild their engine fairly often.
With no adjustments in the bore size, yeah a short piston will rock more, but honing technology and ring packages today should allow plenty miles from a combo such that we are discussing here. There are plenty of high performance factory cars/motorcycles out there with extremely short pistons lasting a good while. Some of which spin 50% (or more) rpm on a regular basis.
I'm not disagreeing with what you're saying. As a matter of fact, all that you say is true....I'm disagreeing with the severity of the situation. It's not that big of a deal.
I'd likely change my mind if I was trying to build a turbo motor. You can size a turbo such that power production is never a problem. In any N/A build, I'm gonna shoot for as big as I can get.
In the case of my 408, it was supposed to get a 4.100" crank, there just wasn't one readily available at the time we ordered all that **** years ago. I'm still disappointed that it doesn't have a 4.100" crank in it.....then again my tune ups only allow around 7 miles of drive time before a freshen up is needed. ****** turbo trucks.
#55
Mine lasted 49k hard miles...being rebuilt right now with no bottom end damage. Ate a lifter and a lobe. Swapped out the pistons for offset pin Diamonds to reduce wear and rocking. Hope to get more out of it this time around.
#60
They are supposed to.
I still wouldnt do it. The worst wear I saw was not at the bottom of the stroke. I'm sure they are kind of egg shaped down there... but the cyl wall mid stroke looked horrible.
