thunder racing cam specs?
Old Jan 12, 2009 | 01:47 PM
  #21
fastrt's Avatar
11 Second Truck Club
Originally Posted by BlackGMC
Yep i would look into the converter... The lowend is fine, cause your cutting good 60's, however you topend stinks... Last time out I was only shifting at 6250 and i was on street tires and i went 8.7's... If a converter is setup WRONG your topend will suffer... I bet if you dynoed with the TC unlock your graph would look terrible... IMO that converter is not translating the power... You have the SST3600 not the SS3600 correct? This is why I like CircleD cause they build them to spec, Yanks from what i have seen are just off the shelf... For example I called CircleD and inquired about a 3800-4000 converter for my truck, same as Scott's, and he speced me out something different than scotts due to the less weight and TQ....
oh, I see, that sounds right. yes its a sst3600. I will look at circle d and see what they say.
I did call richard at wcch, he gave me some good advice and answered questions about going to a bigger cam vs the one I have now. my thinking was right on some things, wrong on others. but as long as I stay in the 220-224 range I will not have to change air flow parts. he said that the truck intake should give me the most problems with a bigger cam(than 224). I am going to look into the verter, and see what they say.
thanks for your help.
Old Jan 12, 2009 | 03:33 PM
  #22
fastrt's Avatar
called circle d and they said the one I have is what they would recommend but higher stall, which would make it even looser. so the verter is ok, I think the shift points are off. i will fix that and then see about another cam.
thanks for all the info guys.
Old Jan 12, 2009 | 04:20 PM
  #23
BlackGMC's Avatar
Resident Retard
I don't think shift points will solve your problem, but good luck either way...
Old Jan 12, 2009 | 05:21 PM
  #24
blackbeast ss's Avatar
put it on a dyno to get your proper shift points dialed in as well as your lockup point
Old Jan 12, 2009 | 06:20 PM
  #25
fastrt's Avatar
I did, the graph is in the dyno section.
Old Jan 12, 2009 | 06:33 PM
  #26
oh i see, i must have misunderstood you when you said your shift points were off. hope you get your bugs worked out
Old Jan 12, 2009 | 06:49 PM
  #27
fastrt's Avatar
I know what you mean, the higher the str, the less top end power I will have, but the low end is great. I need to call both of them back and see just what my sst3600 str is. what str and stall did circle d say for you.
Old Jan 12, 2009 | 07:12 PM
  #28
KevinF56's Avatar
i'm on Yank's website right now. the highest stalling SST converter i see is a SST3200. are you sure your converter isnt a 3200?
Old Jan 13, 2009 | 04:50 PM
  #29
fastrt's Avatar
yes sir its a sst3600, you have to call dave and get it. you can't buy it off the shelf. they have a ss360,sstb3600,and a sst3600. all with small differences from what I understand.
thunder550
Oct 8, 2015 04:53 PM
OLD BULL
Aug 1, 2015 05:00 PM
FlowmasterMufflers
Jul 22, 2015 12:47 PM
NuckenFuts
Jul 9, 2015 08:45 AM
