tr224 or tsp224 more aggressive?
Baltimore Whore
TSP, it is on XER lobes, I don't think TR's cam is it is a lil more aggressive lobe then a XE, but not as much as a EXR. Also TSP is a bigger lift cam. I believe this is correct
Both companies use Comp to grind their cams. TSP uses Comp XER lobes whereas TR designs their own lobe which is a tad less aggressive than the XER. You really can't go wrong with either as there is less than 3-5rwhp difference between the two apples to apples.
My TR224 112+4 in my LS1 peaked at 6000rpms and held flat to 6300rpms with stock 241 heads. With my Stage II 5.3's it peaked at 6100rpms and held flat to 6500rpms. I had my limiter at 6800rpms.
zblee
11-11-2015 12:41 AM
FlowmasterMufflers
09-11-2015 03:32 PM
FlowmasterMufflers
08-31-2015 05:11 PM
FlowmasterMufflers
08-14-2015 01:04 PM
