Some disgusting pics
Old Jul 20, 2015 | 11:05 PM
  #21
DrX's Avatar
DrX
What kind of rocker arms are you using with those Bronze guides?
Crower shaft mount rollers, LS7 style, 1.8 ratio.
Old Jul 21, 2015 | 01:24 PM
  #22
DrX's Avatar
DrX
Few more pics:
This piston is different. Lighter/more reflective deposits. Melted?
After some scratching, I think it is just crud on the piston.
Looking through an injector boss into an intake port:
Cut plugs:
Old Jul 21, 2015 | 01:52 PM
  #23
GMCtrk's Avatar
Looks bad. Mph was down, motor likely hurt.
Old Jul 21, 2015 | 03:29 PM
  #24
DrX's Avatar
DrX
Just need to find the why(s). Think it should have done better than 124 MPH last year as well.
Old Jul 22, 2015 | 05:05 AM
  #25
Gadgetized's Avatar
I wonder if your rings were butting. Do you know what your intake temps were at the end of a run? I am running more gap on E85 and an external intercooler/turbo combo that should work better to cool the air charge.
Old Jul 22, 2015 | 08:09 AM
  #26
DrX's Avatar
DrX
Last log started the pass at a heat soaked 136* and ended at 180*
Old Jul 22, 2015 | 08:44 AM
  #27
Gadgetized's Avatar
What im wondering is if the rings butted and hurt the cylinder walls. The hurt walls caused excessive blowby, and contributed to pushing oil down the guides. That could have been why you were getting the rear of the valve cover gaskets leaking and the dipstick pushing out. I'm not certain about this, but it is what I was thinking.
Old Jul 22, 2015 | 08:49 AM
  #28
03sierraslt's Avatar
How much boost?
Old Jul 22, 2015 | 09:03 AM
  #29
DrX's Avatar
DrX
how much boost?
19 psi
Old Jul 22, 2015 | 09:24 AM
  #30
George C....'s Avatar
Formerly ScreamingL
time to tear motor down and check for pistons that have busted lands
