Pics of finished 383 "Twisted Stroker"
Here are some short block and finished pics of my Stroker (380 cid) 383
No bling no chrome or braided hoses, I'd rather use the money for go fast parts.
4.020 bore, 3.75 stroke 380 cid
Eagle cast steel stroker crank and 5.7 SIR-I Beam Rods w/ARP (500 hp max)
Keith Black Silvolite, coated, hyperuetectic pistons 10.1:1 with 65.3 cc heads
Clevite bearings, ARP hardware, Felpro gaskets, high volume oil pump w/ welded pick up, plasma moly rings, Pro Comp True roller timing set.
The other mods are listed in my signature.
Engine dyno'd
339 peak hp @ 4600 rpm, 300+ from 1500-5000 rpm slight arc in curve.
466 ft-lbs @ 2500 rpm, 425+ ft-lbs from 1500-5000 rpm nearly flat curve.
carid
Oct 28, 2015 08:24 AM
Pontiac Derek
Sep 19, 2015 01:49 PM
Pontiac Derek
Sep 18, 2015 09:02 AM
