Pics of finished 383 "Twisted Stroker"
Here are some short block and finished pics of my Stroker (380 cid) 383
No bling no chrome or braided hoses, I'd rather use the money for go fast parts. http://i199.photobucket.com/albums/a...erra/00051.jpg http://i199.photobucket.com/albums/a...erra/00011.jpg http://i199.photobucket.com/albums/a...000_0008-4.jpg http://i199.photobucket.com/albums/a...000_0006-5.jpg http://i199.photobucket.com/albums/a...d383pic006.jpg http://i199.photobucket.com/albums/a...d383pic002.jpg http://i199.photobucket.com/albums/a...d383pic005.jpg http://i199.photobucket.com/albums/a...000_0002-1.jpg http://i199.photobucket.com/albums/a...a/000_0003.jpg |
none of the pics will come up for me...
PERMISSION NOT GRANTED :bomb:
Forbidden
You don't have permission to access /photos4213/1/6/68/32/67/0/67326806115_0_ALB.jpg on this server. Apache/1.3.34 Server at upsa-im118.ofoto.com Port 80 |
I fixed the problem, I hope somebody checks back in!
Looking good man. What are the specs on the "Twisted Stroker" :D
Originally Posted by XLR8NSS
(Post 3758771)
4.020 bore, 3.75 stroke 380 cid Eagle cast steel stroker crank and 5.7 SIR-I Beam Rods w/ARP (500 hp max) Keith Black Silvolite, coated, hyperuetectic pistons 10.1:1 with 65.3 cc heads Clevite bearings, ARP hardware, Felpro gaskets, high volume oil pump w/ welded pick up, plasma moly rings, Pro Comp True roller timing set. The other mods are listed in my signature. Engine dyno'd 339 peak hp @ 4600 rpm, 300+ from 1500-5000 rpm slight arc in curve. 466 ft-lbs @ 2500 rpm, 425+ ft-lbs from 1500-5000 rpm nearly flat curve. |
Very nice!
