May have run into a problem during cam install
Old Feb 29, 2016 | 01:11 PM
  #41
Wolftrk99's Avatar
Well now that were getting you straight, get into the glove box and figure out what rpo codes you have so we can figure out what your next step should in fact be.....
Old Feb 29, 2016 | 04:45 PM
  #42
lopy6oh's Avatar
I'm not home yet to check but I believe I have the l96. Lc8 is natural gas compatable I'm pretty sure
Old Feb 29, 2016 | 04:53 PM
  #43
Wolftrk99's Avatar
When you do get around to pulling the cam make sure you check the cam bearings really well... And be prepared to throw a set in it...
Old Feb 29, 2016 | 07:03 PM
  #44
lopy6oh's Avatar
Would this be it?
Old Feb 29, 2016 | 07:44 PM
  #45
Wolftrk99's Avatar
You have l96/6l90/3.73/g80 locker.... Which means vvt, no dod, rectangular port heads.... Ned call and get cam straightened out
Old Feb 29, 2016 | 07:46 PM
  #46
Wolftrk99's Avatar
And again i cannot stress enough.... Check the cam bearings when you pull the cam if anything even might look suspicious, do yourself a favor and put a set in or have a set put it, which will require pulling the engine...
Old Feb 29, 2016 | 07:47 PM
  #47
shupe's Avatar
looks like it.
L96 - VVT Flex fuel
MYD - 6l90E
Old Feb 29, 2016 | 08:09 PM
  #48
lopy6oh's Avatar
I gave em a call a few hours ago and they recommended going with the delete kit being as I already have the non vvt cam. I also asked about running this cam with the rectangular port heads and they said it'll run fine. So what I think I'll do is order the delete kit and run this cam. Then plan on getting a set of cathedral port heads soon, maybe sooner than later depending on inspection of the cam to see how the lifters are working. I'll definetly check out the bearings, and pray they look alright lol
Old Feb 29, 2016 | 09:08 PM
  #49
Wolftrk99's Avatar
I think youll be happier running more of an ls3 style cam but thats just me... Or even with a vvt cam.... Probelm with going to cathedral port heads is that you also need to swap intake as well......
Old Mar 1, 2016 | 06:44 AM
  #50
lopy6oh's Avatar
Yeah I hear ya. It just sucks that I already have this one here and ready to go, and will work well with mods later on down the down. Maybe I'll look at tsp's website and look for a better cam I can exchange this one with
