ls3 in silverado?
Old Feb 6, 2008 | 12:23 PM
cbenavides06's Avatar
Default ls3 in silverado?
will an ls3 swap over into a nnbs silverado? I know it will, but will everything else swap over like the sensors and accessories?
Old Feb 8, 2008 | 12:52 AM
ME Performance's Avatar
I think if yours is a 5.3 and above, it should be a direct fit... Im trying to get an LQ9 into the NNBS 4.8L... still waiting on someone to reply.. ur swap should seem so much more easier, same PCM, same trans, same accessories, only thing I know that might have to be changed is the the intake manifold and also water pump pulley to keep the same accessories.. (take a look at speartechs swap in the forums)
Old Feb 8, 2008 | 08:03 AM
Default thanks
i hope youre right. i'm going to order it today. thanks
Old Feb 8, 2008 | 10:55 AM
jakebdb56's Avatar
IIRC, the LS3 isn't the same pcm at all. E67 or E38?
Old Feb 10, 2008 | 04:58 PM
Default ls3 or l92
whats the difference between the ls3 and l92? i thought both were 6.2l motors.
Old Feb 10, 2008 | 05:13 PM
00Silv4.8's Avatar
isnt the L92 the 454?
Old Feb 10, 2008 | 08:50 PM
Default l92
it comes stock in the denali and escalade. i don't know what it is.
Old Feb 10, 2008 | 09:03 PM
53bowtie's Avatar
(what SDPC says about the L92 6.2L in thier magazine)
the new motor in the denalis and escalades is in fact the 6.2L motor. the L92 refers to the HEAD design and has the L76 designed intake. it is an all aluminum motor with 6 bolt mains and variable valve timing. it has cast-aluminum rockers on needle bearings with roller tips. it produces 403 horsepower and 417 lb.-ft. of torque with a compression ratio of 10.5:1 with 70cc chambers.
(what SDPC says about the LS3 6.2L on thier website)
Starting with the '08 Corvette, the world was first introduced to GM's latest small block V8 creation – the 6.2-liter LS3. A continuation of the industry leading V8 engines from GM Powertrain, the LS3 kicks out 430 horsepower and 424 lb.-ft. of torque. (In the Corvette, those numbers go to 436 hp and 428 lb.-ft. of torque with the optional dual mode exhaust system.) It's a brute of a small block with 376 ready cubes at your beckon call.
OHsixLS3
Dec 27, 2016 09:30 AM
The_W
Oct 28, 2015 09:00 PM
Denali08
Aug 9, 2015 04:34 PM
MWRitter
Jul 27, 2015 09:41 AM
Deceptarado
Jul 8, 2015 05:24 PM
