Comp Cam Rockers
Old Jan 29, 2008 | 06:35 PM
HorsePower Hunter's Avatar
Default Comp Cam Rockers
I have a set of cc rockers 1.7 are they worth using or is it better to stay with stock. I had them once on a 408, but didnt know if they are worth putting on a stock lq4. Heard some people can't turn up with them. Right now I'm getting a turbo installed and the guy installing wants to use them. On the 408 I used value cover spacers for clearance that leaked, but he insures me he can fix it with no leak. Any suggestions???
Old Jan 30, 2008 | 06:18 AM
I know it is the same 1.7 as a stock rocker, but no one knows if they are better than stock or has any opinions all suggestions are appreciated
Old Jan 30, 2008 | 07:00 AM
Doobie's Avatar
I have comp pro-magnum rockers and I had to mill the casting dimples off under each valve cover for them to fit properly. They fit fine with no leaks. Also had to remove the PCV hardware from the rear driver side cover.
Old Jan 30, 2008 | 07:06 AM
jakebdb56's Avatar
if you already have them just go ahead and install them. If you try and sell them used you're not going to get close to what you "should" get for them ya know. I'd say they're better than stock, but not all aftermarkets are. I personally haven't run any GenIII rockers from comp, but my previous experience with their older style rockers was quite pleasant.
Jake
Old Jan 30, 2008 | 04:46 PM
Value covers are milled and ready. Just my spacers leaked last time. I just heard people had problems. I never got last motor right enough to really try them out. Are u running the alum. spacers on yours?
Old Jan 30, 2008 | 06:29 PM
Doobie's Avatar
No spacers...No leaks.
Had them off to adjust rockers after a couple thousand miles and reinstalled with same gaskets. I did sandblast the covers while they were off and now I'm wishing I had painted them too.
Still oil tight.
Old Feb 10, 2008 | 01:14 PM
jkwalkercchs's Avatar
hey are they the comp pro magnums with studs and guide plates poly locks?
Old Feb 10, 2008 | 07:52 PM
Doobie's Avatar
Yes...they are pro-magnum. 1.75 ratio for mine.
Old Feb 10, 2008 | 10:22 PM
no i was askin horsepower hunter if they were i would trade him a set of 1.85s for them
those would be worth putting on
BigEd_72455
Aug 8, 2015 07:37 PM
low2001gmc
Jul 23, 2015 05:10 PM
Ammadien
Jul 22, 2015 08:50 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
4B11T
Jul 13, 2015 03:48 PM
