LS2 cam gear work on LQ9?
Old Feb 26, 2010 | 12:05 AM
budhayes3's Avatar
PT's Slowest Truck
Default LS2 cam gear work on LQ9?
I have a new cam gear that I believe is an LS2 gear, the part number is 12576407. Will this work on my LQ9 that I will be building or is it keyed differently or something? I have an LS2 timing chain to use with it...Thanks
Old Feb 26, 2010 | 07:19 AM
budhayes3's Avatar
PT's Slowest Truck
Well, I found some pics on LS1Tech and the gear isn't keyed any differently, so it should work, it's just a different design gear as it's solid where I believe that mine had holes in it when I last looked at it. So it should work, may be a little heavier though
Old Feb 26, 2010 | 07:52 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Billy, from looking at an LS-style gear (it was an aftermarket set) compared to my stock LQ9 gear set when I put the 427 together, I think they are interchangeable too.
Old Feb 26, 2010 | 08:04 AM
budhayes3's Avatar
PT's Slowest Truck
Cool deal, thanks Erik
Old Feb 26, 2010 | 08:33 AM
hirdlej's Avatar
If it means anything to you, my '05 LQ4 came with a LS2 timing set from the factory. GM even used them in the truck motors
Old Feb 26, 2010 | 08:35 AM
hirdlej's Avatar
Maybe I'm not reading this right but did you say that you swapped an aftermarket chain and used your stock set? If so, I hope not. Timing chains/sprockets are matched. It'd be like using a Yukon branded Ring gear in your rear end and a joe schmoe pinion gear. It may "fit" together but the tolerances aren't exact.
Old Feb 26, 2010 | 09:05 AM
I AM A MOTHERF*CKER
No, you did not read my post correctly.
Old Feb 26, 2010 | 10:29 AM
hirdlej's Avatar
Well then.....
ARC
57
Feb 21, 2022 10:54 AM
The_W
Oct 28, 2015 09:00 PM
Castro45
24
Jul 31, 2015 07:13 PM
EscaTruck
Jul 20, 2015 11:42 AM
caviness
Jul 5, 2015 10:49 PM
