LS2 cam gear work on LQ9?
PT's Slowest Truck
I have a new cam gear that I believe is an LS2 gear, the part number is 12576407. Will this work on my LQ9 that I will be building or is it keyed differently or something? I have an LS2 timing chain to use with it...Thanks
PT's Slowest Truck
Well, I found some pics on LS1Tech and the gear isn't keyed any differently, so it should work, it's just a different design gear as it's solid where I believe that mine had holes in it when I last looked at it. So it should work, may be a little heavier though
Maybe I'm not reading this right but did you say that you swapped an aftermarket chain and used your stock set? If so, I hope not. Timing chains/sprockets are matched. It'd be like using a Yukon branded Ring gear in your rear end and a joe schmoe pinion gear. It may "fit" together but the tolerances aren't exact.
ARC
57
Feb 21, 2022 10:54 AM
Castro45
24
Jul 31, 2015 07:13 PM
