LS1 questions
Old Jan 22, 2006 | 09:30 PM
Default LS1 questions
I found what I believe is a pretty decent deal on a low mile 5.7 LS1 shortblock this week. Going to look at it probably Wed.
Couple of questions for you guys. I'd like to reuse some parts from my truck in order to save some money. Currently the truck has a 4.8 in it. Can I reuse my truck intake on the LS1 along with all the truck assessories? I figure my truck has a bigger oil pan correct? Is there a difference in the oil pumps between the two?
Thanks guys.
Old Jan 22, 2006 | 10:56 PM
hog's Avatar
hog
Your truck parts should bolt right on.
peace
hog
Old Jan 23, 2006 | 10:27 AM
Zick's Avatar
Everything from your 4.8 will bolt directly onto the LS1.
Old Jan 23, 2006 | 05:15 PM
Thanks guys.
Hey Zick, ever ran your truck? I curious what type of times I can expect. I plan to do basically the mods you've got except bigger stall. My truck is a RCSB 2 wheel drive. Are the bigger injectors a must?
Old Jan 23, 2006 | 09:45 PM
Zick's Avatar
Originally Posted by 4.8PWR
Thanks guys.
Never made it to the tracks yet, hopefully this spring.
With my setup I was pushing 90% on my stock 24lb injectors and I'm planning on more so I got a good deal on 31lb injectors off ebay I couldn't pass up.
Old Jan 25, 2006 | 06:22 PM
nightrunner's Avatar
Mr. Obvious
4.8 pistons will work great cuz they are flat tops
Old Jan 26, 2006 | 12:27 PM
Zick's Avatar
If your talking about putting 4.8 piston into the LS1 it won't work. The bore is larger on the LS1 than the 4.8/5.3 blocks. The pistons are too small.
Old Jan 27, 2006 | 05:50 PM
Who the hell asked about 4.8 pistons in a 5.7 nightrunner?
Old Jan 27, 2006 | 06:42 PM
white1's Avatar
I noticed that, but kept my smart *** mouth shut.
Old Jan 27, 2006 | 07:50 PM
99Silver6.0's Avatar
They will fit good!!!
Justin87gn
Sep 10, 2015 12:06 PM
bisqikss
Sep 8, 2015 03:35 AM
iregret
Sep 7, 2015 01:20 PM
Cowboy Tom
Sep 5, 2015 04:29 PM
SWINGRRRR
Sep 3, 2015 07:49 PM
