lq4 crank length
Old Apr 8, 2010 | 12:31 AM
greenturtle05's Avatar
Default lq4 crank length
can someone give me the exact measurement or photos on how far the 99-00 crankshaft stick out vs the 01+ lq4 crankshafts. thanks in advance
Old Apr 9, 2010 | 01:43 PM
Callies Performance's Avatar
FormerVendor
Would it help if i told you that according to our prints, it is 3.000 from the very end of the post to the step on the flange. Feel Free to hit me back if you need more information. -Adam @ Callies
Old Apr 9, 2010 | 07:51 PM
the reason i was asking this was because i bought an lq4 and the crank sticks out a little bit and i needed to know about how much does the short crank sticks out that will fit a 60e behind it. i saw some post that was stating that 99-00 cranks were longer and the 60e wouldn't work with it.
Old Apr 9, 2010 | 09:07 PM
1Bear's Avatar
The difference in crank lengths at the rear of the crank is 3mm. When you spot a long crank you will know it, as the short model just protudes past the seal, while the long crank protrudes about 5/8" past the seal. Here are a couple of bad pictures to give you an idea about what your looking at.
LongCrank.gif?t=1270864617
ShortCrank.gif?t=1270865185
Old Apr 9, 2010 | 09:18 PM
SincalT/A's Avatar
.400" more then later lq4's
Old Apr 9, 2010 | 11:25 PM
Steve Bryant's Avatar
LS1 Tech Veteran
Take a look at this article http://www.enginebuildermag.com/Arti...ankshafts.aspx.
Also, this website http://www.enginebuildermag.com has other excellent reference information on stock engines.
Steve
Old Apr 9, 2010 | 11:37 PM
budhayes3's Avatar
PT's Slowest Truck
Steve
Yessir, great website, 1Bear hooked me up with that website a few weeks ago...a lot of good info there
Old Apr 10, 2010 | 10:50 AM
i cant really see the difference in the picture, but i see that the one with the aluminum heads has the shorter crank. so if it has the aluminum heads it should have the shorter crank? correct me if im wrong.
Old Apr 10, 2010 | 12:23 PM
1Bear's Avatar
As long as the heads were factory installed, that is correct.
RustyD
May 23, 2016 07:04 PM
SSpeeDEMONSS
Oct 3, 2015 08:21 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
trxmxzx
Sep 29, 2015 07:42 AM
Slammed silverado
Sep 28, 2015 06:14 PM
