Large Cam in a 6.0 swap
Old Feb 22, 2006 | 10:41 AM
Default Large Cam in a 6.0 swap
I"ve got a LQ4 6.0 with stock #853 castings with 918 springs and gm 6.0 MLS head gaskets. the heads are not milled.
Can i fit a .595 lift thinking maybe a 233/233 .595 595 112lsa?
thanks
Old Feb 22, 2006 | 11:55 AM
dry_kill's Avatar
I think so, I believe when u get to the .610 range then it starts slapping
Old Feb 22, 2006 | 08:36 PM
v8
17,16,15,14,13,12,11 Drvr
hell that ain't big lol I saw a cam on tech it was 256 256 646 646 112 now that is the cam you need lol j/k, your running the 221 221 551 551 112 cam now? how does it like the 6.0 and any dyno sheets or track times?
Old Feb 23, 2006 | 12:06 AM
ap2002's Avatar
is probably aint too big, I know a guy from LA running a 228/230 on a 6.0?? Im pretty sure you'll need a 3000-3200 converter though...
Old Feb 23, 2006 | 05:31 PM
Dark Halo's Avatar
I am running a 230/236 .591/.601 110lsa in my LQ9 with stage 2 64cc LS6 heads. I did not have any clearance problems.
Old Mar 1, 2006 | 08:41 AM
i bought a tsp 231/237 595/595 112lsa
Old Mar 1, 2006 | 08:53 AM
Sport Side's Avatar
Dyno Graph
Above is a link to Kano's setup put on the dyno and shows what happens when the camshaft is not matched to the heads/intake correctly. He was using a 228/230 profile.
Please let us know of your results. I wouldn't be suprised if your dynos compare very similar to his... Unfortunately.
Old Mar 1, 2006 | 10:13 PM
Dark Halo's Avatar
Originally Posted by Sport Side
Dyno Graph
what heads was he running when he dynoed?
Old Mar 2, 2006 | 03:01 PM
Sport Side's Avatar
WCCH heads. 80% head 'before' the truck intake is strapped on it.
Limited RPM range and a head that is flowing a good portion out that it had brought in... Not a scenario for a 'large' standard split if one at all.
Old Mar 3, 2006 | 07:29 PM
Dark Halo's Avatar
I may look into doing a fast 90mm TB intake before to long. The conversion just seems to be a little pricy.
OHsixLS3
Dec 27, 2016 09:30 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
Jake75
Jul 22, 2015 09:20 PM
Suburban2500
Jul 19, 2015 04:50 PM
Cowboy17
Jul 9, 2015 06:18 PM
