Large Cam in a 6.0 swap
I"ve got a LQ4 6.0 with stock #853 castings with 918 springs and gm 6.0 MLS head gaskets. the heads are not milled.
Can i fit a .595 lift thinking maybe a 233/233 .595 595 112lsa?
thanks
thanks
17,16,15,14,13,12,11 Drvr
hell that ain't big lol I saw a cam on tech it was 256 256 646 646 112 now that is the cam you need lol j/k, your running the 221 221 551 551 112 cam now? how does it like the 6.0 and any dyno sheets or track times?
Dyno Graph
Above is a link to Kano's setup put on the dyno and shows what happens when the camshaft is not matched to the heads/intake correctly. He was using a 228/230 profile.
Please let us know of your results. I wouldn't be suprised if your dynos compare very similar to his... Unfortunately.
Originally Posted by Sport Side
Dyno Graph
Originally Posted by Dark Halo
what heads was he running when he dynoed?
Limited RPM range and a head that is flowing a good portion out that it had brought in... Not a scenario for a 'large' standard split if one at all.
GrooveCityZ71
Aug 31, 2015 12:05 PM
Suburban2500
Jul 19, 2015 04:50 PM
