got the new engine in, now truck wont start!!
Old Oct 2, 2007 | 11:13 PM
  #31
TG02Z71's Avatar
Originally Posted by BlackGMC
Since his block and heads are aluminum can you still ground the wires to them? I did not think aluminum can conduct current?
Aluminum is actually more conductive than steel or cast iron. Unless of course it has a non-conductive coating applied to it such as certain anodizations or hard coatings, the heads probably don't have suck a coating on them but who knows.
Hop you get your truck issues fixed soon so you can enjoy your new powerplant!!
Old Oct 2, 2007 | 11:20 PM
  #32
Tootall's Avatar
is your temp gauge hooked up? I unplugged mine once after it was started, and it killed the engine.
Security light flashing after it's running? I know that it keeps it from starting.
What about disconnecting the battery over night to let it reset itself?
A bad cell in your battery or bad connections would keep it from starting. Is your battery a sealed, or does it have caps? Any white/green funk on the connections? Make sure that your connections on the block are metal to metal . . . . no paint between the two.
Old Oct 3, 2007 | 01:26 AM
  #33
dry_kill's Avatar
temp gauge is hooked up.
security light is not on.
might have to try the battery thing
battery is the same one that came with the truck
no white or green funk. truck only has 12k on it
all connections are metal to metal. i connected the grounds to the bellhousing bolts
Old Oct 3, 2007 | 09:12 AM
  #34
Tootall's Avatar
I'm stumped
guessing it's something with the way that the trans is hooked up.
Does the gear selector match the indicator on the dash?
What about calling the guy that did the trans rebuild, pick is head about the neutral safety switch.
Old Oct 3, 2007 | 09:37 AM
  #35
dry_kill's Avatar
ya the gear selector matches the dash. i really dont know what it is. i think it may just be the starter going out or the relay. I know when i tried to start the truck for the first time, i had 2 of the wires on the starter barely touching so when i would put the negative terminal up to the battery then engine would start turning over without even having the key in. i wonder if doing this may have damaged the starter
Old Oct 3, 2007 | 01:11 PM
  #36
PappyDan's Avatar
Tribe Shaman
i take it now that after the motor is started, it will stay running after
you placed the grounds on new locations?
but your now having an issue with the starter only?
take the starter to be tested, easy to do.
with the starter out and the help of a friend use a test light
on the starter connections.
make sure the hot wire and the block grounds make the test light
nice and bright.
used the same ground for the key wire, have your friend turn the key
and see if it lights up every time the key turned for the truck to start.
if it light up every time your good.
if it does not light up, start running down the wire until it does light up.
Old Oct 3, 2007 | 06:39 PM
  #37
dry_kill's Avatar
well took the truck to a shop today. they said it is definately not the grounds that it has something to do with the relay switch and the box. thing is he said it is gunna take awhile to fix. he said he couldnt even give me a time frame. that he doubts the truck will even be ready by friday
Old Oct 3, 2007 | 10:16 PM
  #38
Tootall's Avatar
well if he's saying that . . . sounds like something is "grounding out" somewhere.
My weekend project might be getting put on hold . . . want some help?
Old Oct 4, 2007 | 05:04 AM
  #39
dry_kill's Avatar
i would but the truck is in the shop. im letting them deal with it, thing is they said they are gunna have to keep it a few days to fix it. i hope this aint gunna cost too much considering i took it to hpe
Old Oct 4, 2007 | 08:22 AM
  #40
Tootall's Avatar
Originally Posted by dry_kill
. . . i hope this aint gunna cost too much considering i took it to hpe
I haven't heard/seen posted a single good thing about them in a while
