GM LS 9 camshaft
Old Feb 6, 2010 | 07:06 AM
Default GM LS 9 camshaft
Wondering if anybody had a chance to test the GM LS9 camshaft in a supercharged truck? I understood that they work on the LS1,LS2 aswell.
They are actually dirt cheap.
211/230 @ 0.50 duration
.558/.552 lift w/1.7 rockers (could try 1.8"s on it)
122.5 centerline.
Old Feb 6, 2010 | 10:02 AM
budhayes3's Avatar
PT's Slowest Truck
Those specs look like it would be great with a supercharger If I understand it correctly, Lingenfelter discontinued one of their cams (GT7 or something like that?), because it's specs were so close to the LS9 camshaft, and those Lingenfelter cams were known to be good boost cams
Old Feb 6, 2010 | 10:09 AM
smokeshow's Avatar
Mod with training wheels
Yeah, just check out the LS9 engine...a supercharged 6.2L with: an LS9 cam! lol
Puts out 626/585, so it does well for it self, IMO... I put the GT-7 in my 5.3 only to discover a month later that a flood of $150 LS9 cams came spilling out of GM's doors
Old Feb 6, 2010 | 10:13 AM
gmcboy2002's Avatar
im fixin to cam my '02 5.3 and was told not to mess with the rocker cuz......well u kno what happens when u run to big of a cam!
Old Feb 6, 2010 | 10:59 AM
budhayes3's Avatar
PT's Slowest Truck
I have a question that may be of some concern...if you run the LS9 camshaft do you have to replace the cam gear and timing cover? I don't believe that the cam has the lobe for the cam sensor on the rear of the camshaft. Also is it a single bolt or 3 bolt camshaft? You may need to get a different cam gear, cam gear bolt, timing cover and cam sensor, and run the wires to the cam sensor to the front of the engine.
Old Feb 6, 2010 | 11:14 AM
Doobie's Avatar
Sounds interesting for my 5.3L Radix. Does anyone have a GM part # for this LS9 cam? Need to know more about cam gear, cover and sensor relocations/replacement. The low cost for cam could offset modifications needed for running it.
Old Feb 6, 2010 | 11:20 AM
1Bear's Avatar
I wouldn't really consider your post as much of a question as it is the answer for anyone contemplating using a Gen IV cam in a Gen III application.
Old Feb 6, 2010 | 11:36 AM
SILVERADO11's Avatar
I am very interested in the LS9 camshaft for my 5.3 as well. LPE recommend it it for my application when i talked to them on the phone last. but i would like to find someone that is already running it and here how its doing, and if they needed ti change anything to run it.
Old Feb 6, 2010 | 12:48 PM
budhayes3's Avatar
PT's Slowest Truck
Cool deal, thanks man
Old Feb 6, 2010 | 02:32 PM
GM LS9 # 12605527
GM LS7 # 12571251
211/230
.593/.590
120
The LS7 might be a good cam also.
Chances are it would be a single bolt cam though......Could call Lingenfelter and find out.They advertise it as a LSx series cam.
