Finally got all my parts!!!
Old Jun 29, 2009 | 10:18 PM
  #21
charcold-bowtie's Avatar
air fitting can be had at any autozone. just get a compression checker.
Old Jun 30, 2009 | 09:30 PM
  #22
ok, so i have the w/p off, rad out of the way,rocker arms off , PRs out, but now to get the balancer off......can i use my impact to get it off as long as im careful? if not whats the bestway to to do it to keep motor from turnin? im damn close so all help is GREATLY APPRECIATED!!!!!!
2000sierra6.0, check ur messages, I PM'd u, check it ls1tech
Old Jun 30, 2009 | 10:23 PM
  #23
nonnieselman's Avatar
Make sure you use a socket or something on the crank to keep from messing up the threads.. we took it off with a ratchet/socket with ease.
Old Jun 30, 2009 | 10:28 PM
  #24
so i can use my impact??? im goin to use my 1/2" impact with 24mm socket< im talkin bout takin out the crank bolt!!
Old Jun 30, 2009 | 10:32 PM
  #25
oh the ballancer bolt?
yea a impact will be fine, just make sure your careful when you put it back on..
get the ballancer on then tighten up the timing cover
Old Jun 30, 2009 | 10:34 PM
  #26
absolutely!!! thanks man
Old Jun 30, 2009 | 10:52 PM
  #27
Atomic's Avatar
I have a gauge for that
I used my 12" socket wrench, itll come right out
I jammed a screwdriver in the flexplate so it wouldnt turn.
Old Jul 3, 2009 | 12:01 AM
  #28
whew....looooong nite. started workin ont he truck at 330 today, got the new cam in and all the springs are installed. got the front cover loosley on, need a second hand to help hold the motor from turnin so i can put on my balancer. Other than that, just everything back together, hard part is done, and so am i, updates tommorow!!
5.3Caprice
Nov 7, 2015 08:56 PM
TXsilverado
Sep 26, 2015 12:48 AM
nickpc82
Aug 30, 2015 09:18 PM
Fast86z
Aug 23, 2015 12:35 AM
mrhino
Aug 7, 2015 10:01 AM
