help with my cam installation
Old Jun 29, 2009 | 02:24 PM
2000sierra6.0's Avatar
Default help with my cam installation
im swaping my cam on my lq9 im ready to take the cam out i installed the 5/16 wood rod but the lifters are still sliding down and the 3/8 rod will not fit in any help will be appreciated
Old Jun 29, 2009 | 02:27 PM
KySilverado's Avatar
Use the lifter trays if they will work at all. Spin the cam with the push rods out and try and "sling" the lifters into the trays. I used aluminum rods, the 5/16 rod required a flat ground down one side to slide in.
Old Jun 29, 2009 | 02:40 PM
i put the 5/16 rod all the way in but the first lifter on the right and the last one on the left still fall the 3/8 rod ii did the flat ground on one side but i only got it half way i might grind it a little more see if that will work
Old Jun 29, 2009 | 03:30 PM
nonnieselman's Avatar
Pen magnets?
i bought 16 of them for my cam install.. Northern tool FTW..
Old Jun 29, 2009 | 04:01 PM
thanks for the help i gess im going to geet the magnets
Old Jun 29, 2009 | 04:11 PM
they were $1.50 i think... and you always need a magnet.
Helps with valve spring installs too
Old Jun 29, 2009 | 04:30 PM
yes yes and i can also give them out for christmas lol
Old Jun 29, 2009 | 04:40 PM
with engine oil on them right?
Old Jun 29, 2009 | 04:46 PM
castrol syntec jajajja
Old Jun 29, 2009 | 06:32 PM
006rcsb's Avatar
Wtf is jajajja?
