engine swap, how hard can it be???!!!
Old Feb 14, 2006 | 06:41 PM
dry_kill's Avatar
Default engine swap, how hard can it be???!!!
Ok fellas, I'm saving up for my LQ9, I'm a little over halfway there, this one shop will charge me 1600 bucks to swap it for my current 5.3, I was wondering, is this something I could do myself? Or should I just say **** it and wait another 5 months to save up 1600 bucks??? Thx fellas
Old Feb 14, 2006 | 06:45 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
Do you have any friends with mechanical skills that could help? It's alot easier with at least one other person.
Old Feb 14, 2006 | 06:59 PM
dry_kill's Avatar
Ya I got a buddy that knows a few things about cars, but just one, my other friends can't even change there own oil, I mean I know a few things about engine, I just figure it can't be too hard, just the hardest thing is making sure all the electrical stuff is unplugged, its not like I'm taking the engine apart, just a direct swap, what u fellas think? Anything else I should look out for? Thx o yea, and tools won't be a problem, got a buddy with a air compressor n plenty of tools, any special tools I might need?
Old Feb 14, 2006 | 07:31 PM
99Silver6.0's Avatar
Its not too bad. Took my time, did the engine, tranny and converter in almost 2 days with a few little snags.
Old Feb 14, 2006 | 08:35 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
You can do it. Its not that hard to do. When are you planning on doing the swap?
Old Feb 14, 2006 | 08:56 PM
Zick's Avatar
dry_kill's Avatar
i plan on doing the swap in about 2 months, still gotta save up a little bit more money for it
Old Feb 14, 2006 | 09:03 PM
dry_kill's Avatar
i might wait longer to do it, because im going to cam it, and i would much rather put the cam in it while its out, then to put it in then have to take it back out to put the cam in, well i doubt i'll put the cam in myself since i know nothing about how to put a cam in, but i know labor will be cheaper if i bring them the engine with the engine out
Old Feb 14, 2006 | 09:18 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Put the cam in yourself. There is a write up on LS1Tech or somewhere with step by step instructions. Since the motor will be out a cam swap is cake! I bet you could do the cam swap in a couple of hours, much faster if a buddy is helping you. If your doing springs it will take a little longer. The engine swap itself is 90% labor, 10% brain power. Label everything you take off or disconnect with masking tape or something. Most plugs will only reach the socket they go in and most all have unique shapes so its pretty hard to fudge it up. Engine stand, cherry picker and your basic tools and get to it. If your thinking of making it a high revving engine you might want to get some Katech rod bolts. Quick and easy swap while on a stand. Keep saving your $$ It just gets more expensive from here.
Old Feb 14, 2006 | 10:08 PM
dry_kill's Avatar
I think I'm just scared of doing it because I always have bad luck when it comes to doin things to my truck
