Different heads questions
Old Aug 26, 2012 | 09:08 PM
03 BLKTAHOE's Avatar
Default Different heads questions
I'm getting ready to rebuild a 5.3 which I will be turboing and I would like to put heads on. The problem is I hear different numbers thrown around like 799, 315 and so on and I'm totally in the dark on what I should be looking for. If you guys could let me know what heads you would recommend and possibly shed some light on all the different heads and the numbers that are thrown around I would greatly appreciate it.
Thanks
Old Aug 26, 2012 | 10:01 PM
grey matter 04's Avatar
13 Second Truck Club
https://www.performancetrucks.net/fo...g-info-434396/
This give you info on all the heads!
Old Aug 26, 2012 | 10:24 PM
Thanks grey matter 04 that is really good info. If I read right the 243's are the zo6 heads and are good for all out power but the 317 and 035 are good if your going for boost.
Old Aug 26, 2012 | 10:26 PM
just watch the combustion chamber size affects compression
Old Aug 26, 2012 | 10:27 PM
ltr450ryder's Avatar
317s wouldn't do u any good on a 5.3 cuz the chamber cc is way to big for it bring Ur cr 243s would be a good one even if u boost it and still would bring Ur cr down but not a lot
Old Aug 26, 2012 | 10:35 PM
243s and run a thin gasket so you dont have to mill them to get back to stock compression or close to it
Keep that head surface thick so it holds plenty of boost
Old Aug 27, 2012 | 11:10 AM
I'm new to all this is there a gasket that you would recommend? Thanks I'm now on the hunt for some 243's..
Old Aug 27, 2012 | 12:58 PM
zero2sixT's Avatar
Heads are pretty much the last thing I'd worry about on a boosted engine. Look around here and see what guys are doing with stock heads and forced induction.
I would not run a thin head gasket on a boosted engine.
Old Aug 30, 2012 | 10:47 AM
Sales3@Texas-Speed's Avatar
Truck Sponsor
As far as factory castings, the 243s would be the best option for your setup as far as a N/A build. Although, I would mill them instead of running the thinner gasket for the compression bump.
5.3lSilverado
25
Aug 29, 2016 12:48 AM
USMCvet0311
Aug 1, 2015 07:45 AM
bbowerman
Jul 26, 2015 10:57 PM
sauldgold
Jul 23, 2015 02:15 PM
