lifter preload experts take a look
Old Aug 25, 2012 | 11:41 PM
lavoy's Avatar
Default lifter preload experts take a look
hey guys i recently redid my 4.8 turbo set up with some better valve springs and while i was at it upgraded the ls6 style lifters i had in it to the ls7 style. with the ls6 lifter i used a 7.375 push rod and got just at or under 1 3/4 turns till 22 ft ibs. with the new ls7 lifters im getting a tad over 1 3/4 turns and when i fired it up it clanked and rattled like all heck. it finally started to idle quietly as i left oil pressure flow threw the lifters but as soon as i would try and rev it it would get noisy again and clank around and stall. i think the push rods are to long , after reading around i think i want to order a push rod thats 30 thou shorter. the chart i saw said that 30 thou would equal about a 3/4 of a turn and im a tad over 1 3/4 now. does this all sound correct? so if i have a 7.375 now i want a 7.345 correct? also does any one think i hurt any thing running it? it does run quiet as long as i let it idle if i rev it thats only when it starts to clank around.
Old Aug 26, 2012 | 05:21 PM
lavoy's Avatar
oh and after you take a look please feel free to reply lol 63 views and no replys isnt good.
also added a video 2012 08 26 13 07 51 872 - YouTube
Old Aug 26, 2012 | 06:10 PM
black4.8's Avatar
not a good noise. shouldn't hurt it if you don't drive it too long like that. i'd just pick a pushrod lenth checker. they are cheap. mine checked out right at 7.4 w/ stock lifters and cam base diameter. the lifters aren't pumped up fully until you rev it up.
Old Aug 26, 2012 | 06:46 PM
Atomic's Avatar
I have a gauge for that
That turn method BS is probably the worst thing to come along in years...
Get a pushrod length checker for $10 and measure to see what you need.
Old Aug 26, 2012 | 07:04 PM
Ferocity02's Avatar
What cam and thickness head gaskets are you using? FWIW I needed 7.350" rods with LS7 lifters, stock head gaskets, stock base circle cam.
Old Aug 30, 2012 | 10:57 AM
Sales3@Texas-Speed's Avatar
Truck Sponsor
This is the best advice.
Although measuring that way can give you a round about idea of what length might get you close, I will have to agree with you 100%!
JordanH
Nov 6, 2015 07:42 PM
gmcyukon
Oct 5, 2015 06:20 AM
santoy956
Sep 10, 2015 03:12 PM
chvy=power
Sep 8, 2015 11:06 AM
Cowboy Tom
Sep 5, 2015 04:29 PM
