Cant understand my cam specs
Well what can you cam gurus say about this cam?
intake : 247 / .607lift
Exhaust: 240 / .607lift
LSA: 114
Recommended intake centerline: 110
has 4 degrees of overlap and is a lunati grind.
LSA: 114
Are you sure the intake and exhaust arent mixed up?
Usually blower cams have more exhaust duration than intake.
Say a 240/247 .607/.607 114 lsa instead of your listed 247/240 .607/.607
Well I don't know either intake opens 2deg btdc and exhaust closes 2deg atdc which makes it 4.
Specced based on too many details however and this is one of the reasons Im asking about the cam cause I can't understand it at all lol
Pretty odd cam choice....
Very low overlap which is good for mileage, but I doubt you care about that on your setup. Big duration for a truck and especially a supercharged big engine truck, and the reverse split for a roots supercharger is very odd. Lift is fine, maybe leaving a little on the table depending on what heads you have. LSA sure is tight for a blower...
Sounds like this cam is specd for high peak power, but I dont think it would work well in your application., but what do I know...
