Cam suggestions for lq4
My silverado isn't my daily, but I've used it as one more than a few times. I run a 230/236 on a 114. IMO, a 220's cam is a little small for a 6.0. Especially one with a t56 behind it.
The 90mm intake is a nice mod. Also, I'd install an underdrive pulley on the crank, while the engine is out. Not a huge gain in power, but every little bit helps.
Op started a legitimate thread. Don't know why you're shitting on it with a lame *** joke.
You don't have to run a 220s cam to keep a 6.0 streetable. Imo, you'd actually want to give up SOME low end torque in a reg cab truck. Every vid I see on here with a 220s cam, 3600 stall and 4.10s has a dig run going up in smoke.
https://www.performancetrucks.net/fo...d.php?t=482150
https://www.performancetrucks.net/fo...d.php?t=473829
https://www.performancetrucks.net/fo...d.php?t=476207
https://www.performancetrucks.net/fo...d.php?t=476005
https://www.performancetrucks.net/fo...d.php?t=464212
https://www.performancetrucks.net/fo...d.php?t=471883
Because there's been a lot of thread on this and things similar. When people don't use the search button, John gets angry, and you don't wanna see him when he's angry.
Yah you said it
Yah some times these ?? get just a bit old. There has to be 20 of them a day?? Just do a search.. The site is old now, plenty of info, not like the beg of it, when the info was not there.. To the OP there is a WIDE variety of cams to choose, poss a few that work better then the gt cam's for a NA set up..
Hey guys I talked with Ron at Vengeance Racing and he recommended the VRX4 for my application so I think I will go with that one. Thanks to those of you who contributed constructively to my post I appreciate it.
