Cam limitations for nitrous
Old Mar 30, 2023 | 11:19 AM
06murder's Avatar
Default Cam limitations for nitrous
I’m run the comp 224/230 on 114 I run 250 shot on, but it seems like runs better on a 200 then 250, didn’t gain much. Fastest pass with 200 shot was 7.13 and fastest pass on 250 was 7.09? Do y’all think I’m bout to the limits of the cam? Time to upgrade?
Old Mar 30, 2023 | 12:46 PM
RDF1's Avatar
DuNnO
5 Year Member
Yep!
Get a dedicated nitrous cam and it will make a difference.
Ive got buddys that run this cam in SBE 6.0s with either a Vic Jr or a holley High ram. Doubt the TBSS intake will work great with it tho.
https://cammotion.com/in-stock-ready...-single-plane/
Bad thing about a nitrous cam is they usually arent spectacular off nitrous.
What are you solenoid Orfice sizes?
Have you flowed your nitrous kit?
Old Mar 30, 2023 | 01:46 PM
06murder's Avatar
.122/177 nitrous outlet
Old Mar 30, 2023 | 01:52 PM
06murder's Avatar
Thought bout get tick performance 5.3 nitrous cam
Old Mar 30, 2023 | 02:23 PM
TXsilverado's Avatar
which nitrous kit. you could be running into the limit of your system as well.
Old Mar 30, 2023 | 02:27 PM
06murder's Avatar
I have 122/177 nitrous outlet solenoids nitrous outlet plate with 82/44 jet -4 fed line standalone with c16 set at 55 pounds
Old Jul 3, 2023 | 07:38 AM
headsup9550's Avatar
5 Year Member
It has nothing to do with your cam. You're blowing through your torque converter when you're putting more nitrous pill in it. Therefore, your ET doesn't change much
Old Jul 3, 2023 | 02:22 PM
RDF1's Avatar
DuNnO
5 Year Member
I think i asked about converter slip in high gear in another thread.
05GTO6SPEED
May 14, 2008 09:07 PM
sclac5.3
Jun 30, 2007 06:22 PM
chevy_69k20
Apr 15, 2007 11:12 AM
00stepsyde
Jan 31, 2007 06:29 PM
really slow truck
21
Sep 27, 2002 07:40 AM
