are all cams good with nitrous?
Old May 11, 2008 | 08:14 PM
05GTO6SPEED's Avatar
Default are all cams good with nitrous?
are all cams good with nitrous or do some handle it better? ive got a 222/224 on a 112lsa @ .566/.568 and was thinking about a 100 wet shot. by the way its on a 04 5.3 silverado
Old May 11, 2008 | 08:57 PM
Mangled03gmc's Avatar
Baltimore Whore
All cams will work with nitrous, but there are cams that are ground just for Nitrous, just as there are cams ground for turbos and blowers. You will be fine running a 100 shot with that cam....
John
Old May 11, 2008 | 11:36 PM
LMSeven's Avatar
Unless you have a direct port nitrous dedicated motor, I'd run a solid N/A cam, since your driving around N/A 99% of the time, spraying 1%.
Old May 12, 2008 | 09:02 AM
BOTLFED_AWD's Avatar
formerly lamborado (1-12-2012)
you'll be fine but in the future for the best performance ive been told run a 114 LSA for the juice, but most the guys i know running the spray have a 112 so i dont know how much water that holds, but most cams are okay for steroids.
Old May 12, 2008 | 10:48 AM
7845's Avatar
Banned
IMHO n20 cams are waste of time for average person. unless you have a pure track vehicle that lives on N20 then it is a waste....NA cam is where its at for 99% of ppl
Old May 12, 2008 | 10:57 AM
Hawk179's Avatar
Correct on this one. The last thing you want to do on an N2O cam is add more exhaust duration for to make more RPM, then you render the N2O less effective where it should be, down low.
R
Old May 12, 2008 | 06:32 PM
ap2002's Avatar
yup, i have a friend running a cam on a 22x/23x 110lsa, and his truck runs alot better than mine, and he sprays his all the time... my next cam will be on a 110lsa...
Old May 14, 2008 | 09:07 PM
ok thanks for the info
ARC
57
Feb 21, 2022 10:54 AM
OHsixLS3
Dec 27, 2016 09:30 AM
Greatdivider
Sep 9, 2015 09:52 AM
USMCvet0311
Jul 29, 2015 01:28 PM
elpyro89
Jul 28, 2015 05:51 PM
