Cam bearings q ?
Old Oct 21, 2009 | 07:09 PM
Michael Halo's Avatar
thanks guys for the help
Old Oct 23, 2009 | 08:11 PM
Beatdown Z's Avatar
Laid Back
Originally Posted by Hawk179
Brass is normal on these blocks because the brass is not from the cam wear. GM line hones the block with the bearings in them. So thats what you are seeing. Unless the bearings are messed up and not in normal condition, dont change them.
Rick
Hmmm... I recently bought a 5.3 with a wiped out cam lobe and it's showing some Brass in the cam bearings. Seems like they're all worn in the same spot too. So they might be ok?
Old Oct 24, 2009 | 01:10 PM
budhayes3's Avatar
PT's Slowest Truck
I've seen a lot of pics of brassy cam bearings on Tech, and when I did my cam swap at 37K my front bearing was kind of funky looking. Swapped the cam in and it's been 23K so far with no problems. When I bought my 27k LQ9 I noticed that the first cam bearing in that is showing a lot of brass too...from what I've seen and read here, I don't believe that it's a problem.
Old Oct 24, 2009 | 01:13 PM
Hawk179's Avatar
yes its normal. You will find all the blocks have the same look in all the same places. Its from them line honing with the bearings in the journal.
R
5.3Okasai
Mar 9, 2022 01:07 PM
ARC
57
Feb 21, 2022 10:54 AM
AUTOT3K
Aug 16, 2015 06:21 PM
Jake75
Aug 5, 2015 01:26 PM
Dezert1500
Jul 30, 2015 02:51 PM
