another heads intake question...
Old Feb 2, 2011 | 09:10 PM
~VH~'s Avatar
Default another heads intake question...
ok im needing some help deciding here i have a ext cab shortbed silverado. im swapping in a lq4 and im wanting to make 400 minimum hp im getting longtubes, tune, stall (likely 2500-3000) and the cam is 236/242 580/590 112(not absolutely set on the cam).. im just not sure what heads/intake will get me their. i have a set of ported 241's laying around but am not sure about useing because id have to mill to make power and ptv clearance? or am i wrong? should i go with a different cam? id like to stick with gm O.E. heads and not l92s... with that said id like to not drop a grand on a f.a.s.t. intake/tb. so should i go with edelbrock proflo? ls6? bbk? i dont ever plan on towing so thats not an issue. ive just been having a hard time figuring this one out
thanks in advance guys
Old Feb 3, 2011 | 09:52 AM
~VH~'s Avatar
would these be a good choice?
http://cgi.ebay.com/ebaymotors/CNC-L...#ht_3713wt_941
Old Feb 3, 2011 | 10:18 AM
00buckshot's Avatar
I wouldn't put those heads on a 6l engine, look for some 243 casting heads on ebay. have them milled to get CR up to say 11.1 and haul ***!
Old Feb 3, 2011 | 10:42 AM
regency's Avatar
either cam is too big for stall or stall is too small for cam, either way you want to look at it.
Old Feb 3, 2011 | 11:01 AM
~VH~'s Avatar
i thought the 241's and 243's were the same besides valves? and the biggest stall id put on it is a 3200 (its a dd) think id be fine with that?
Old Feb 3, 2011 | 11:59 AM
~VH~'s Avatar
would these 243s do good?
http://cgi.ebay.com/ebaymotors/LS6-5...#ht_500wt_1182
Old Feb 3, 2011 | 10:11 PM
regency's Avatar
seriously a 3000 feels no different than stock. Im running a 3800 and you can tell its in there but its not like damn what a stall! i DD'd mine for a while until i got a 30mpg car for $600. You could probably go with a mid to high 220's cam and a 3200 stall and reach your goal with a 6.0
Old Feb 3, 2011 | 10:13 PM
regency's Avatar
Also beware of heads like that without a flowsheet or even specs from a manufacturer
Old Feb 4, 2011 | 09:29 AM
~VH~'s Avatar
Ok thanks alot!
The_W
Oct 28, 2015 09:00 PM
USMCvet0311
Sep 30, 2015 10:34 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
Denali08
Aug 9, 2015 04:34 PM
fat tony157
Jul 16, 2015 12:35 PM
