6.0 problem flexplate wont turn
Old Dec 19, 2008 | 11:38 AM
  #31
00ChevyScott's Avatar
Wearin' da big hat
Put the pushrods back in and spin the cam and get all the lifters stuck in the trays, then one by one push them back down onto the cam to check that all the lifters are there.
What method did you use for keeping the lifters there? Pen magnets? Dowels? JPR tool?
Old Dec 19, 2008 | 11:59 AM
  #32
I tried that too and i spun the cam, pushed each pushrod down and one by one they all moved. I don't think a lifter fell down. I used wooden dowels. Now im leaning towards it being the crankshaft. Should i pull the oil pan out? If not i guess im going to have to pull the engine out
Old Dec 19, 2008 | 12:11 PM
  #33
Wearin' da big hat
It has got to be something in the bottom end, as long as all the valves are closed and the timing gear is disconnected like you said.
Did you try pulling off the flywheel and turning it? Did you hit the motor on anything when you set it down into the truck? You would have to hit something pretty damn hard to bend that crank man.
Old Dec 19, 2008 | 12:25 PM
  #34
budhayes3's Avatar
PT's Slowest Truck
Yea, now that you mentioned it, you'd be short one lifter and have a pushrod falling down into the crankcase if you dropped a lifter...
Old Dec 19, 2008 | 03:00 PM
  #35
Ok i think i found the problem. We got the engine out. we got the flywheel bolts loose and guess what?? It spins!!!!.... now did i tighten them too much? they were torqued to 74 lb according to a post i saw about torque specs.
Old Dec 19, 2008 | 03:07 PM
  #36
KySilverado's Avatar
Too Long would be my guess? Don't see how torquing them would affect anything.
EDIT: IF to long would they seat into the bearing cap or something?
Old Dec 19, 2008 | 08:00 PM
  #37
viciousknid's Avatar
Where's the Beef?
Haven't seen the back side of an LSX engine yet, but if they are too long they'd either do that or hit the block.
Put em back in and See if they hit anything.
Y2KLimited
Dec 5, 2015 09:57 AM
dry_kill
11
Aug 28, 2015 09:53 PM
ALL ULL C
Aug 16, 2015 08:56 PM
03regcab sierra
20
Aug 3, 2015 12:11 AM
