6.0 problem flexplate wont turn
Old Dec 18, 2008 | 03:12 PM
Default 6.0 problem flexplate wont turn
Getting ready to finish my buddies 6.0 swap and cam install. When trying to turn the motor over for the converter bolts. the motor isn't turning ive tried it from the crank bolt and it wont turn it was turning fine when aligning the dot on the timing chain.
Im using the flexplate from the 5.3 60e so that should be good.
The 6.0 came from his 03 2500 chevy truck, so the motor was working fine. Anybody know what could have gone wrong?
Old Dec 18, 2008 | 03:25 PM
mine was hard as hell to turn even now with 500 or so miles on it !
Old Dec 18, 2008 | 03:38 PM
i dont want to risk breaking the crank bolt, i hope that its just hard to turn over
BIRCHZ71's Avatar
i just had this problem....is there plenty of space between the converter and the felxplate? on mine they were wedged together. mine was a result of the converter not being all the way on. prob not the case if you didnt mess with the converter.
Old Dec 18, 2008 | 03:39 PM
krambo's Avatar
Did you take the spark plugs out? Does it not turn in any direction?
Old Dec 18, 2008 | 03:42 PM
the spark plugs are out on one side of the motor, the motor wont turn by itself the converter is out now
Old Dec 18, 2008 | 03:52 PM
Mangled03gmc's Avatar
Baltimore Whore
Did you just put this motor in or have the tranny out, during any of this???
John
Old Dec 18, 2008 | 04:11 PM
Yes this is a swap, the transmission is out and was out when we tried to turn it
Old Dec 18, 2008 | 04:23 PM
Baltimore Whore
I think that the flexplate, converter are binding up when your turning it, to get to the next bolt. Try to tighten them just a lil bit at at time.. Do one a lil bit, then go to the next. It takes a lil longer, but that could be the prob..
John
Old Dec 18, 2008 | 04:34 PM
thunder550's Avatar
High on diesel fumes
If the trans is out....
Are you sure you got the cam lined up right? Rockers tightened down correctly? Pushrods seated into the rocker cups correctly? Sounds like you might have a valve that's hanging open contacting a piston or something like that.
