6.0 problem flexplate wont turn
Old Dec 18, 2008 | 04:36 PM
Mangled03gmc's Avatar
Baltimore Whore
Originally Posted by thunder550
Read the post above you, noob! Tranny is out
Are you sure you got the cam lined up right? Rockers tightened down correctly? Pushrods seated into the rocker cups correctly? Sounds like you might have a valve that's hanging open contacting a piston or something like that.
Ohhh I misread that, sorry jeeze take it easy on the new guy... In that case I must agree with what you said then, I hate agreeing, so I am going to agree to disagree... hahahha
John
Old Dec 18, 2008 | 04:57 PM
charcold-bowtie's Avatar
yeah those crank bolts are pretty dam stout, something is def wrong.
Old Dec 18, 2008 | 05:41 PM
If the trans is out....
Yes every rocker was torqued ect. While the engine was out i spun it and everything turned fine. I'm going to take the covers off and see if anything is wrong.
Old Dec 18, 2008 | 06:19 PM
skeet's Avatar
you sure you installed the correct flex plate? might wanna take it off again and see if the motor turns. think you mentioned it turned fine before you had the flex plate on
Old Dec 18, 2008 | 07:39 PM
yeah correct plate, i just tried it again a its freakin hard, crank was turning fine when i had the motor out, that's where i did the cam and springs
Old Dec 18, 2008 | 08:08 PM
viciousknid's Avatar
Where's the Beef?
I'd take the timing cover and valve covers back off and make sure everything is how it should be.
And take ALL the plugs out instead of just one side.
Old Dec 18, 2008 | 08:29 PM
just took valve covers, every valve is there.
also all spark plugs are out timing cover up next
Old Dec 18, 2008 | 08:37 PM
BIRCHZ71's Avatar
lol hey mangled i see you got your post count back...geeezzz i think they threw in a few extras in there for ya.
Old Dec 18, 2008 | 09:30 PM
Ok got the rockers, pushrods, cam gear out and still the same.. Wont want to turn. Might it be that a bolt got into the intake side of the heads there somehow?? or the flexplate put on backwards?
Old Dec 18, 2008 | 09:39 PM
Where's the Beef?
I don't think a backwards flexplate can cause that unless it's physically hitting something.
Better grab a flash light.
