5.3L's year to year diffrences?
Old Jul 14, 2008 | 08:50 PM
TG02Z71's Avatar
Default 5.3L's year to year diffrences?
I have two 5.3l engines, one bought from someone here and the one in my truck. One is from a 1999 or a 2000, mine is a 2002.
Going to get the machining underway soon and am wondering which is better for my build into a 5.7l?
Any ideas or suggestions??
Thanks.
Old Jul 14, 2008 | 08:57 PM
mcfarlnd's Avatar
Un-Registered User
both are the same. heads might be a different casting but, the 2000 will be good to bolt your 2002 parts to or vice versa
Old Jul 14, 2008 | 08:58 PM
00ChevyScott's Avatar
Wearin' da big hat
the 06 5.3 block I got was exactly the same except for the fuel system. Same heads, same intake (besides DBW), same water pump, everything. The only thing I had to change was the temp sensor on top of the block
Old Jul 14, 2008 | 08:59 PM
GMCtrk's Avatar
flip a coin
Old Jul 14, 2008 | 09:53 PM
InchUp's Avatar
Originally Posted by GMCtrk
flip a coin
If it comes down to it, yes, I'd flip a coin since the differences are subtle that have nothing to do with the machining.
I would keep the running 5.3L in your truck and build the 5.7L on the side to lessen the down time of the truck.
Old Jul 14, 2008 | 10:06 PM
lady3bglover's Avatar
He's got a point, lessen the amount of down time...
Old Jul 14, 2008 | 10:40 PM
TouchOfEvil04's Avatar
i thought they upgraded the rods?
or was that just the 6.0l motors?...i forget..
Old Jul 15, 2008 | 08:19 AM
TG02Z71's Avatar
I thought the early cranks were cast VS forged? These are the deatils I'm looking for.
New rods will be used so thats not a big deal and I also have a set of 317s off an SS truck.
Old Jul 15, 2008 | 09:10 AM
InchUp's Avatar
That'll work for sure. Mill the 317's down to match the right head gasket and compression ratio you're after. Anywhere in the range of 9.8-10.3:1 you'll still be alright on cheap gas.
Old Jul 16, 2008 | 05:56 AM
TG02Z71's Avatar
I was thinking close to stock compression ratio would be best since I will stay with a turbo set up for added power.
