5.3 heads
Old Aug 1, 2010 | 04:20 PM
c5z28's Avatar
Default 5.3 heads
I have supposedly seen heads with a 2.00 intake valve fit on the 5.3 bore, but I am curious to know if 2.02/1.6 valves will fit on a 5.3 bore. If the cylinder walls need to be notched that's fine but if you can post a link since this would be something new to me. Thanks for all help
Old Aug 1, 2010 | 05:48 PM
006rcsb's Avatar
the prc stg 2.5 5.3 heads have 2.02/1.575 valves in them
http://www.texas-speed.com/shop/item...id=84&catid=40
Old Aug 1, 2010 | 06:04 PM
Mark Johnson's Avatar
Hmm, i know most everyone goes 2.02 intakes after machining. That brings up another question; what's better- wome outta the box 243's or some 5.3 heads that have been CNC'd by like TEA......................
Old Aug 1, 2010 | 08:18 PM
brent5631's Avatar
Some ported 5.3 heads would be better for sure.
Old Aug 2, 2010 | 12:30 AM
c5z28's Avatar
The question is regard to some Absolute speed heads that have already been ported milled to 58cc and have the valves I stated above. They made 455rwhp and 405rwtq with a vengeance cam on an ls-1 for anyone who is curious. Don't care about brand just curious if they will fit the bore with the specs they have.
Old Aug 2, 2010 | 01:14 AM
1FastBrick's Avatar
Custm2500's Rude Friend
I Have a feeling they would fit but since a 2.00 Valve starts to shroud in a 4.8/5.3L Bore on a flow bench. I can only Imagine The problem would be more obvious with a Larger valve.
Old Aug 2, 2010 | 10:44 AM
swift700's Avatar
Default I'm trying the same thing.
I just posted a similar question over on the LS1 site. I have a set of 243 heads with 2.02/1.57 valves that I'm thinking of putting on my 5.3. After measuring across the valves the width is 3.720 from one valve across to the other valve. In a 3.780 bore that leaves .060 or .030 from the edge of each valve to the cylinder wall. That is if everything lines up perfectly. I seems really tight but I'm not sure what an acceptable clearance is. I'm waiting for someone more knowledgeable to chime in and offer an opinion.
Old Aug 2, 2010 | 11:54 AM
swift700's Avatar
Here's a pic of the 2.02/1.57 valves showing the measurement.
I might just notch out the cylinders for these valves. I will decide today as I'm going to start my blower installation.
Old Aug 2, 2010 | 12:37 PM
swift700's Avatar
This is a fairly common practice for tight valve-to-cylinder clearance. I lifted this pic from another site but it shows the reliefs ground in:
I think this is what I'll do for the added clearance safety margin. It also improves flow by unshrouding the valve somewhat.
JordanH
Aug 8, 2015 07:59 PM
elpyro89
Jul 28, 2015 05:51 PM
steves86ta
Jul 28, 2015 10:21 AM
vmaxpro
Jul 27, 2015 10:45 PM
06 4.8
Jul 15, 2015 07:17 PM
