317 on a 06 5.3
Old May 23, 2009 | 01:25 PM
Biggsw784's Avatar
Default 317 on a 06 5.3
Curious what has to be done as far as running a 317 on a 5.3. i have read it somewhere but i cant remember what was done. milling them down or something?? Thanks for any help.
Old May 23, 2009 | 03:29 PM
marlboroman71818's Avatar
slap em on and go. what are you wanting to accomplish with them? Are you FI or NA?
Old May 23, 2009 | 03:47 PM
SincalT/A's Avatar
Rick from Synergy but, he is twin turboed w/ bout 14 to 18 lbs.
Old May 23, 2009 | 04:16 PM
joeyc125's Avatar
11 Second Truck Club
I would say those are not the best heads for a 5.3. The valves are too big for a 5.3 bore, and your compression will be way down. Need more info on your setup for us to help you out though.
Old May 23, 2009 | 07:08 PM
Rick_Vor's Avatar
Rick said it knocked him down to 8.5:1.
Rick
Old May 24, 2009 | 02:54 PM
chevyfan956's Avatar
Not good for N/A
Old May 25, 2009 | 02:07 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
get 243's mlled if you want NA or leave 'em at 64cc for FI on the 5.3 WAIT, what engine is the '06, the L33 or LM7?
Old May 25, 2009 | 08:54 AM
litreddevil's Avatar
Banned
you need to give more info as of what you are wanting to do na/fi why do you want this
if you do this n/a i would angle mill the heads so you can run a good size cam if you flat cut them you are limited on the cam angle milling puts the valve farther away flat milling puts the valve closer.other than that you can just bolt them on just need to know what you are wanting to do.
Go5.3tt06
25
Sep 4, 2016 10:25 AM
pewter00
Sep 14, 2015 09:17 PM
11MPG
Sep 8, 2015 04:52 AM
bisqikss
Sep 8, 2015 03:35 AM
pewter00
Sep 7, 2015 10:14 PM
