243's on 5.3
Old Nov 27, 2007 | 05:06 PM
  #51
Wheatley's Avatar
Truck Sponsor
I got new stock replacement gaskets.
Old Nov 27, 2007 | 08:52 PM
  #52
joshua022's Avatar
Will I need to get bigger injectors if i do this swap?? possibly 8.1 injectors??
Old Nov 27, 2007 | 09:11 PM
  #53
Derek @ EDO's Avatar
FormerVendor
I don't think you will, but it would be a nice upgrade for future mods.
Old Nov 27, 2007 | 09:13 PM
  #54
joshua022's Avatar
I need to check with my tuner and see if my injectors are close to being maxxed out yet. If so then I'll get some 8.1s if i do the swap.
Old Nov 27, 2007 | 09:15 PM
  #55
FormerVendor
Yep, check your IDC, most recommend not going past 80%
Old Nov 28, 2007 | 01:08 PM
  #56
dkota1968's Avatar
I have a set of 243s in my basement collecting dust. Now tell me if im right: stock gasket size is .053" and the stock LM7 CC is 61cc. The LS2 heads are 65cc and the ratio of milling .006 equals 1cc on 243s. How far would I need to mill to get a 10.5-1 or 11-1 comp ratio? Could also use a flatter gasket like .041" to help with the smaller combustion chamber.
Old Nov 28, 2007 | 03:52 PM
  #57
Truckshop's Avatar
i don't remember how far you can mill them before you have clearence issues. mine are milled .040 with stock gaskets and if i had to guess my cr should be between 10-10.5. so with a thinner gasket it should be easy to get where you want to be. it would take someone smarter and more precise than me to give you specs.
Old Nov 28, 2007 | 06:02 PM
  #58
dkota1968's Avatar
Ill have to look further, thanks for the reply
Old Nov 28, 2007 | 08:41 PM
  #59
joshua022's Avatar
My buddy has some on his LS1 and they are milled .055 with stock gaskets and he doesn't have any clearance issues.
Old Nov 28, 2007 | 09:03 PM
  #60
TouchOfEvil04's Avatar
sweetness.
