243's on 5.3
Old Nov 27, 2007 | 12:52 PM
  #41
Derek @ EDO's Avatar
FormerVendor
Originally Posted by Truckshop
try 12573949. i think
did you get a line on a set of heads?
Lol, your a regular on here now huh?
  #42
joshua022's Avatar
Yeah I did I have 2 I'm looking at, both are off a 06 corvette so they are LS6 heads with the sodium filled valves. One set is stock for $400 shipped and the other are ported and I can pick them up for $500. Haven't decided which ones I want yet though.
Old Nov 27, 2007 | 12:54 PM
  #43
joshua022's Avatar
should flow better as it is 90mm!
Would you need to get injectors from a TBSS and all that??
I guess you would have to get a LS1 water pump and an idler pulley relocation bracket also??wouldn't you??
Old Nov 27, 2007 | 12:57 PM
  #44
Truckshop's Avatar
didn't know how popular this swap would be!!
Old Nov 27, 2007 | 01:01 PM
  #45
Truckshop's Avatar
i have the injectors intake tbody and rails. all i need is the ls2 adapter harness. all the parts are off my brother-in-laws tbss. i get to keep the parts i replace. he put cnc'd ls6 heads 225/230 cam and a ported intake. he is in the process of replacing the rails and injectors so i will have the whole assy. from looking at it looks like it will bolt right up. it is a tall intake so no need for the ls1 water pump or bracket.
Old Nov 27, 2007 | 01:03 PM
  #46
joshua022's Avatar
Awesome, those are the best kinds of parts.
Old Nov 27, 2007 | 01:05 PM
  #47
Truckshop's Avatar
or they at least have the best price. plus it gives my wife someone else to be mad at for having to do all the work!
Old Nov 27, 2007 | 02:02 PM
  #48
Wheatley's Avatar
Truck Sponsor
I've got the 243 heads that came off a LS2 GTO.I had them milled .035.Good heads for what I paid for them.
Old Nov 27, 2007 | 02:04 PM
  #49
joshua022's Avatar
What kind of gasket did you use? Did you use a 5.7 gasket on yours also??
Old Nov 27, 2007 | 04:04 PM
  #50
iamkeniff's Avatar
about how much power are you expecting out of this swap
