243's on 5.3
Old Jan 16, 2008 | 02:34 AM
  #91
20002wdchevy's Avatar
14 Second Truck Club
i know this topic is being beaten to death but I have a few questions for you guys that have already milled/installed the 243's. How much do you have to mill them to get 10.0-10.3 cr with stock gaskets? and would it be better to mill them less and run a thinner gasket like the cometic .041 instead of milling them more with a stock thickness gasket? Sorry if these are dumb questions I just can't seem to find it elsewhere. thanks again
Old Jan 16, 2008 | 05:49 PM
  #92
Truckshop's Avatar
mine are milled .040 i am not sure what the cr is cause i did not measure anything. as far as gaskets if you are paying to get them cut then why have to pay 100 bucks for gaskets also. it is cheaper just to cut them the extra amount. stock gaskets are cheap.
Old Jan 16, 2008 | 09:47 PM
  #93
Canucktrux's Avatar
are there any intake fitment issues after cutting .040 off the heads?
Old Jan 16, 2008 | 10:20 PM
  #94
Banned
I Talked To Wcch And They Said Ppl Have Done .060 Without Intake Fitment Issues So I Did .045 On Mine But I Havent Put Them On Yet
Old Jan 17, 2008 | 05:58 PM
  #95
Truckshop's Avatar
nope. intake bolted right up.
Old Jan 21, 2008 | 08:02 PM
  #96
Derek @ EDO's Avatar
FormerVendor
That is correct
Old Jan 26, 2008 | 09:10 AM
  #97
jkwalkercchs's Avatar
so wats the ptv clearance max lift i can run with a set of 243s on my 5.3 with 4.8 flat tops
i think they were milled .30 they have 57cc chambers so whatever thats close to
Old Jan 26, 2008 | 02:29 PM
  #98
joshua022's Avatar
the heads you got from me were milled .055, and the guy i got them from had them on a camaro running the FM-13 cam. I'm not sure of the specs but it was around 228/230 and .595lift (i think)
Blwn99x
Sep 11, 2015 09:27 PM
97gmc
22
Sep 8, 2015 10:56 PM
custm2500
Sep 8, 2015 05:53 PM
bisqikss
Sep 8, 2015 03:35 AM
screaminian47
Sep 7, 2015 08:20 PM
