4.8 flat tops in a 5.3
Old Jan 25, 2008 | 07:37 PM
jkwalkercchs's Avatar
Default 4.8 flat tops in a 5.3
has anybody done it i have searched and couldnt get a straight answer
Old Jan 25, 2008 | 08:37 PM
AHha I thought this is why you wanted the pistons.I'm pretty sure its been discussed on here b4.
Old Jan 25, 2008 | 08:38 PM
joshua022's Avatar
They will work fine and it will up your comp ratio a little bit.
Old Jan 25, 2008 | 08:44 PM
like how much with stock gasket and those 57cc heads????
Old Jan 25, 2008 | 09:01 PM
joshua022's Avatar
11.18:1 SCR
and around a 8.69:1 DCR (depending on the cam you choose)
Old Jan 25, 2008 | 09:10 PM
im just puttin a 01zo6 cam with some 1.85 rockers or maybe 1.75s if that guy trades me
Old Jan 25, 2008 | 09:44 PM
IMD's Avatar
IMD
Banned
remember though that the 4.8 has a different stroke, and different rod length than the 5.3. that means the pin is in a different location. the flat top isnt the only difference.
Old Jan 25, 2008 | 09:51 PM
TurboGibbs's Avatar
pin height is the same, rod length makes up the difference in stroke.
Old Jan 25, 2008 | 09:58 PM
IMD's Avatar
IMD
Banned
ah. ok then.
Old Jan 25, 2008 | 10:10 PM
kbracing96's Avatar
I wish somebody would try this, it's been talked about a dozen times, but haven't actually seen where someone has done it.
