2007 and newer truck owners with cam swap please step inside
Old 03-12-2018, 09:17 AM
rennat_2006's Avatar
What engine is this on? If a 5.3 or smaller your vac is gonna be significantly lower then stock. I would guess your map kpa is in the 70 range at warm idle. That cam is 3 deg overlap. If this is in a daily driver with a otherwise fairly stock setup that’s a poor cam choice. What stall speed converter?
Boosted2007- for reference your cam is -6 overlap, so 9 deg overlap less. That’s significant.
All your map code threasholds will need adjusted.
2008 suburban 5.3. Has exhaust other than that it is stock. Stock stall, was told it wouldnt need a higher stall then i notice a week after i had installed it btr puts note on their website that it may need higher stall to consult with tuner. Fabulous
How did you figure out the overlap #? I cant find any other info on this cam other than what i posted above
Old 03-12-2018, 09:49 AM
Btr customer service is great! I just talked to there technical support and i should have never been recomended that camshaft. They are swapping me out with a btr stage 1 truck cam.
Old 03-12-2018, 10:32 AM
03sierraslt's Avatar
Originally Posted by madmann26
My cam is +11.5 overlap.
Zero codes. It's tuned.
I go back to the issue being with the tuner.
Correct, but that cam is horrible for his combo. A Suburban with a 5.3 and stock stall with that cam is gonna be a major turd.
Glad to hear BTR is swapoing it for you, you will be much happier with what they send you.
As has been pointed out, if your cam has enough overlap your idle MAP kpa will be high enough that the computer thinks you have a air leak and it will throw a code, I forget the code but if memory serves me right it’s like P0068 or something. You have to adjust the threasholds in the tune.
Old 03-12-2018, 07:07 PM
B00sted2007's Avatar
Yeah.... I really know the bare minimum about camshaft specifics! Haha
Old 03-12-2018, 08:05 PM
For whoever asked. Cam overlap-
(Intake Duration + Exhaust duration) / 2) - (LSA X 2)
(224+230)/2)-(112x2)
227-224
3 deg overlap
Or just use a online calculator.
slowlsx
07-30-2009 09:07 PM
mjdwyer23
03-20-2007 11:30 AM
MyGoatBites
10-30-2006 07:27 PM
XLR8NSS
10-02-2004 02:02 AM
ZYA_LTR
09-20-2004 07:01 PM
Quick Reply: 2007 and newer truck owners with cam swap please step inside
