2007 and newer truck owners with cam swap please step inside
Anybody with a 2007 or newer truck or suv with a aftermarket cam swap did you have any issues with vacuum?
Map sensor codes?
Service brake system messages?
Etc
Fighting this on my 2008 suburban and trying to figure out if this is a normal thing or if i have problems/issues elsewhere that need to be addressed.
Map sensor codes?
Etc
224/230 112+3 .500
Its the NSR (no springs required) budget cam from BTR. I installed blue ls6 spring on it though while i had heads off replacing the lifters.
Its being custom tuned but he thinks it has a vac leak because of how low it is. Ive been all over it and done every trick i know of and cant find a thing.
224/230 112+3 .500
always a chance of the intake manifokd gaskets leaking when you put it all back together. Not sure what intake manifold gaskets you used, but I like the metal ones with the thick silicone/rubber gaskets on each intake port! I’ve never had a issue out of them! Anyways about the cam, I don’t think it should cause any issues! Maybe the tuner can get it squared away!
Those are the gaskets i used.
Its been smoke checked, pressure checked, smoke with pressure, sprayed down around underneath and behind with brake cleaner, and tested with propane out of a hose to get into the nook and crannys.
Anyway you can get a vacuum reading on your truck for me?
What engine is this on? If a 5.3 or smaller your vac is gonna be significantly lower then stock. I would guess your map kpa is in the 70 range at warm idle. That cam is 3 deg overlap. If this is in a daily driver with a otherwise fairly stock setup that’s a poor cam choice. What stall speed converter?
Boosted2007- for reference your cam is -6 overlap, so 9 deg overlap less. That’s significant.
All your map code threasholds will need adjusted.
