Keeping VVT and AFM with a cam swap?
Old Dec 2, 2014 | 09:11 PM
Bit's Avatar
Bit
Default Keeping VVT and AFM with a cam swap?
I saw that Comp Cams now makes 3 cams that keep VVT and AFM for the K2xxx and C7 platforms. Two of them look like good truck cams while the other is mostly vette.
I was wondering what everyone thought about keeping all that stuff with a cam swap. I know the majority of people will say take it all out. I think GM has fixed the lifter problems so I'm not scared of AFM failure. I was just trying to get pros and cons before I pulled the trigger.
Old Dec 2, 2014 | 11:26 PM
Noah Burns's Avatar
Great topic, can't wait to see what the truly educated and intelligent members have to say about this topic
Old Dec 3, 2014 | 06:56 AM
Bit's Avatar
Bit
Thanks. The cam and lifters are only $440 and the phaser limiter kit is only about $60. Various gaskets and a tune, in my book, makes this a good affordable swap. I like being able to keep all the factory stuff and mod at the same time.
Old Dec 3, 2014 | 07:31 AM
Noah Burns's Avatar
You plan on doing the work yourself? Throw head bolts or studs I. There too if you're planning on doing lifters. I think I heard of read somewhere that there is an "hd" timing set on the market for these engines as well
Old Dec 3, 2014 | 11:04 AM
Bit's Avatar
Bit
Yeah I will be doing this myself when I do it. I got the idea from Truckin Magazine. They did one, but didn't show any results. All they showed where the install pics.
Old Dec 3, 2014 | 01:30 PM
Vortec350ss's Avatar
I'd not feel comfortable leaving afm. It's designed for super soft lobes and springs... The comp cams won't be up to those standards and it will stress a system that's already suspect in most people's eyes.
Not to mention leaving afm will really limit your cam selection. I can't imagine a cam that's worth it's salt will behave well in 4cyl mode.
Old Jan 27, 2015 | 08:53 PM
craigsix's Avatar
i have the dod/vvt comp cam in my 2012 5.3. sounds tuff and runs pretty good. i also have the 1.8 yella terra ultralies and blue springs. tuned by area 47. best mph 102. 689-421-13#
Old May 12, 2015 | 12:30 PM
14silverado1990's Avatar
Registered User
Itching to pull the trigger on a cam for my 14' DCSB 5.3...
Old May 22, 2015 | 04:50 PM
David@Vengeance's Avatar
^^ This.
We installed the 270PIIHR17 in a customer's truck and it only picked up 15rwhp over stock at 4,000RPM+. No gain anywhere below that, and the idle had a barely noticeable lope. It's a lot more time, money, and effort to delete the DOD/AFM system, but well worth it not only for safety of the engine but also performance.
Old May 25, 2015 | 11:12 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
DOD/AFM lifters are garbage and have no place in a performance application. They already have very high failure rates in bone stock engines driven by soccer moms.
OHsixLS3
Dec 27, 2016 09:30 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
MattOKC
Aug 18, 2015 11:30 AM
Matt331
Jul 26, 2015 09:40 PM
Aboss
Jul 9, 2015 10:28 AM
