valve train noise?
#33
7702-1 Comp Cams Adjustable Pushrod Checker
Have you checked your pushrod length instead of guessing or going by what others have used?
Don't guess
Don't guess
#35
I think I would get to checking rockers and springs, I have a 2012 that I did a dod delete, a bigger vvt cam and used ls7 lifters with 7.400 pushrods and mine doesn't have any noise like that....
#36
What would you suggest to check the springs? They all looked ok when I had the cover off yesterday and the rockers did as well. So my next option would be try the proper length push rods
#37
Every cam spec'd with a stock head, LS7 lifters, stock rockers is a 7.425" its not a "guess" it's what Pat G, Geoff @ EPS, texas speed, allen @ futral have all spec'd to keep preload right.
If it was broken springs that noise would be at idle, cruise, wot, hot motor, and cold motor.
I run 7.4 in my 6.2 with milled .020" heads, 7.425" in my dod deleted 5.3
#38
John at tsp shipped out some 7.425s today. He appologized for the screw up and even knew it happened once I gave my info.
I doubted a bad spring...cause they are new with the cam and I thought the sound would be way worse.
#39
