valve train noise?
Old Jan 8, 2013 | 09:16 PM
AUTOT3K's Avatar
Default valve train noise?
noise video
I started getting this ticking noise tonight and I'm suspecting maybe loose rocker arms? Is that common?
Old Jan 8, 2013 | 09:24 PM
Choda's Avatar
Ouch... Sounds like u need to pull it over and pull the valve covers ASAP
Old Jan 8, 2013 | 09:34 PM
AUTOT3K's Avatar
now that I have a minute to explain, i'm on a computer not my phone
I took the truck STRAIGHT home and kept RPMS low as I could.
I did my cam last week and almost did a trunion upgrade, I torqued everything to 22ft/lbs and went over it twice. buttoned up the covers all was well.
tonight I was doing a data log and I did a great WOT run, and when I let off to decel...that noise started!
strange thing is...if I let it sit for 2-3 minutes off then start it back up noise goes away until I rev it to about 2000rpm!
AUTOT3K's Avatar
is it common to pull the valve cover and have to retorque those comp cam trunion kits?
Old Jan 8, 2013 | 10:08 PM
iamkeniff's Avatar
The trunion upgrade requires 25ftlb or 27ftlb also make sure you arent loading the lifter when you are torquing them. There is a certain step to doing it so you are on the smallest side of the cam, not the peak lobe
Old Jan 8, 2013 | 10:18 PM
AUTOT3K's Avatar
So I double screwed up cause I torqued to the factory 22ft/lbs and didn't do it on the base circle either cause a guy I worked with was like "they aren't valves you gotta lash they just seat and torque the bolt"
Old Jan 8, 2013 | 10:48 PM
AUTOT3K's Avatar
so best case scenario and they are just loose
would blu loc tite be something to consider on the studs?
Old Jan 8, 2013 | 11:11 PM
iamkeniff's Avatar
I use a small dab of red loc tite
The 22ftlb is the reason they came loose i bet
Old Jan 8, 2013 | 11:17 PM
AUTOT3K's Avatar
well I'm gonna pull off the covers tomorrow afternoon and check, shouldnt take me to to long and hopefully it is just a loose thing, not a stripped threads or failed lifter...
BUT the noise is quite high in the engine, like id ALMOST bet money on it being cyl 1 or 3
Old Jan 9, 2013 | 05:25 PM
AUTOT3K's Avatar
So my initial torque at 22 check to see I got almist 1/4 turn outta some.
Everything seems solid. Ill do the rest down to 27 and update
