valve train noise?
#21
when the noise originally started I was data logging for black bear, so I emailed him the issue, as well as the code info and even a link to the video just to get his thoughts too. I listened to some you tube videos of "pinging" and a couple sounded similar...
#23
my theory behind it is...its gone when the engine is cold, starts once it gets warm...combine that with a slightly off tune and I could be pre igniting?]
could a bad spark plug cause that? I did drop one of the packs during install...
Im just spouting off random ideas now.
does anybody else on here use EFI LIVE and could check the log?
#25
You are trying to fix a problem with the wrong pushrods. So the preload is wrong on the lifter as it is.
Id get the 7.425" install them, go for a drive.
As far as i know with efi live you can scan KR, if so then you will see the KR spiking up
#26
well I emailed TSP and sent my info/order stuff and hopefully they'll work something out about the wrong push rods cause to flat out order new ones its like $120 without shipping so i'm not happy about that!
but would that .025" really make that kinda noise? and only on 1 maybe 2 cylinders...and cause that lean code?
I dont have an ls1tech account but I spent some time looking at their old threads about push rods to short and none of their sounds match mine...they reference the "sewing machine" a lot and mines not like that!
#29
Alright read your whole thread and it does sound like your pushrods are too short after listening to the vids I would just order a set of the 7.425 then see how things change. You just take one step at a time. I would just call and ask tsp explain what they did and tell them you need the 7.425 overnighted to you for there mix up
#30
