valve train noise?
Old Jan 9, 2013 | 11:33 PM
  #31
2000chevysilverado's Avatar
I dunno just call and find out
Old Jan 10, 2013 | 07:41 AM
  #32
AUTOT3K's Avatar
Justin got back to me. He said my knock sensor started going nuts at 5200rpm. Basically when I start getting that noise. So I'm gonna get on those damn push rods today!
Old Jan 10, 2013 | 08:46 AM
  #33
cdub81's Avatar
7702-1 Comp Cams Adjustable Pushrod Checker
Have you checked your pushrod length instead of guessing or going by what others have used?
Don't guess
Old Jan 10, 2013 | 09:39 AM
  #34
Area47's Avatar
ya know. i have a set of 7.425 push rods from brian tooley racing. not going to be doing anything with them.
Old Jan 10, 2013 | 10:08 AM
  #35
Sales2@SDPC's Avatar
Trucks Sponsor
I think I would get to checking rockers and springs, I have a 2012 that I did a dod delete, a bigger vvt cam and used ls7 lifters with 7.400 pushrods and mine doesn't have any noise like that....
Old Jan 10, 2013 | 12:24 PM
  #36
AUTOT3K's Avatar
What would you suggest to check the springs? They all looked ok when I had the cover off yesterday and the rockers did as well. So my next option would be try the proper length push rods
Old Jan 10, 2013 | 12:54 PM
  #37
iamkeniff's Avatar
Every cam spec'd with a stock head, LS7 lifters, stock rockers is a 7.425" its not a "guess" it's what Pat G, Geoff @ EPS, texas speed, allen @ futral have all spec'd to keep preload right.
If it was broken springs that noise would be at idle, cruise, wot, hot motor, and cold motor.
I run 7.4 in my 6.2 with milled .020" heads, 7.425" in my dod deleted 5.3
Old Jan 10, 2013 | 02:28 PM
  #38
AUTOT3K's Avatar
John at tsp shipped out some 7.425s today. He appologized for the screw up and even knew it happened once I gave my info.
I doubted a bad spring...cause they are new with the cam and I thought the sound would be way worse.
Old Jan 10, 2013 | 02:33 PM
  #39
Area47's Avatar
mine only had noise when it was cold when the ls9 spring parted ways
Old Jan 10, 2013 | 03:04 PM
  #40
iamkeniff's Avatar
Skipperdaddys broke spring sounded like a 471 detriot with dead injector
