valve train noise?
Old Jan 16, 2013 | 05:06 PM
  #101
rcsb jon's Avatar
Originally Posted by NEGEN@SDPC
If what your saying about the pushrods is true then answer this for. All LS engines after 2007 that are not a DOD lifter are a ls7 lifter. So with that said when you look in the GM catalog if you look at a 2001 LS or a 2009 LS3 or a 2010 5.3l the pushrod part number never changes (10238852) from a stock 7.400 length.....The pushrod length is not only based on lifter but also based on the base circle size of the cam, deck height of head, and deck height of the block........
Agreed... with all of this.
op... you better clarify your push rod length with an engine builder and clarify about that seal. Playing guessing games to save a buck or two is gonna be costly in the long run
Old Jan 16, 2013 | 05:29 PM
  #102
AKlowriderZ71's Avatar
11 Second Hall Moniter
Originally Posted by AUTOT3K
Hmmm. Lets hope this fixes it! ! Definitely wrong size
I believe you're on the right track.
Old Jan 16, 2013 | 05:52 PM
  #103
iamkeniff's Avatar
Ok so i guess pat g and geoff at eps are the dumb ones for specs that require a 7.425" push rod on every gen 4 motor ive ever put a cam in or done a DOD delete on
As for the o-ring its always best to just buy the right one from the dealer for your truck imho
Old Jan 16, 2013 | 05:53 PM
  #104
Area47's Avatar
the lifter is the same size from ls2-7-9 whatever it may be, it's the cup height inside the lifter thats different. a quick search on ls1 tech yields this information
Old Jan 16, 2013 | 07:21 PM
  #105
AUTOT3K's Avatar
https://www.youtube.com/watch?v=HZxh...e_gdata_player
Crappy vid but a little beating. Most importantly my idle psi is over double last night and at wot its almost triple. After a good beating. About fI've wot pulls is where this video ends off. Valve train is almost dead silent
Old Jan 16, 2013 | 07:27 PM
  #106
2000chevysilverado's Avatar
Sounds 10 times better and when ya opened hood up sounded like normal valve train noise
Old Jan 16, 2013 | 07:31 PM
  #107
03sierraslt's Avatar
Good to see you got it sorted out.
Old Jan 16, 2013 | 08:05 PM
  #108
oakley6575's Avatar
Nice man!! how long did it take you to pull the pan and swap the o ring?
Old Jan 16, 2013 | 08:14 PM
  #109
AUTOT3K's Avatar
About 1.5hrs. So kinda slow haha.
Its a 2wd so it was really simple
Old Jan 16, 2013 | 08:16 PM
  #110
oakley6575's Avatar
Thats not bad at all. Did you drain the oil first?
