?'s on 12 6.2 I'll be looking at
Old Feb 9, 2014 | 04:25 PM
02SilveradoLT's Avatar
Default ?'s on 12 6.2 I'll be looking at
I'm looking to get into a different truck and a local dealership just got in a low mileage 2012 ccsb lt 6.2. Anyways they listed the truck as having 3.42's? I guess I've always been under the assumption that these trucks had 3.73's? The truck does have a tow package. Also what year did these trucks switch to the 6sp? Flame on I did some searching my skills obviously suck...
Old Feb 9, 2014 | 04:35 PM
Bit's Avatar
Bit
3.73 come in Z71. I believe 6sp started in 08 or 09. If you test drive it, you will buy it. But the 2014 6.2 is a lot faster and nicer truck.
Old Feb 9, 2014 | 04:56 PM
Yeah I'm not really sure I want to step up to the 14. Truck is a z71. Weird, I wonder why they listed the truck as having 3.42's and a 4sp? I'm excited to go look at it. My cousin recently bought a Yukon Denali which I rode in yesterday. All I can say is wow! I'm totally sold on the 6.2 for a great big suv like that it f'n rips!
Old Feb 9, 2014 | 05:00 PM
01FormulaTA's Avatar
3.73 is part of the NHT package....very easy to check...tell them to send you the rpo codes....GU6 is 3.42, GT4 is 3.73...most 6.2 trucks have 3.73s...my truck is not a 4wd or z71 and has 3.73s from the factory..2011 CC 6.2 2wd
Old Feb 9, 2014 | 05:09 PM
craigsix's Avatar
my 2012 rcsb 5.3 has 6speed and 3.42s. that is had 3.42s 4,10s now. 6speed started in 2010 i think.
Old Feb 9, 2014 | 05:17 PM
NKPPhil's Avatar
I can't say for sure about the 2012s but in '11 when I was shopping the ONLY way to get 3.73 gears was with the NHT (Max Trailering) package, and that ONLY was available with a 6.2. You couldn't get NHT with Z71, and you couldn't get Z71 with 3.73 gears. Like 01FormulaTA said check the codes, GT4 is 3.73. If it's got that it will also have the NHT code.
The NHT also gave you four-wheel disc brakes (rear drums were standard in '11), Z85 suspension with different shocks, a 9.5" 14-bolt "automatic-locking diff, and I think I remember that there was some kind of better radiator or cooling.
Old Feb 9, 2014 | 06:27 PM
Thanks for the help guys. I'm going to email the dealer again for the rpo codes. Is there a big difference between a max trailering vs the normal 6.2 in terms of performance?
Old Feb 9, 2014 | 06:36 PM
Bit's Avatar
Bit
If you can get a vin, I will tell you exactly what it is and its complete warranty history.
Old Feb 9, 2014 | 06:39 PM
3GCPKSE22CG150822
Hell yeah man. Thanks!
Old Feb 9, 2014 | 06:58 PM
Bit's Avatar
Bit
GU6 3.42 gears
L9H 6.2L V8
MYC 6spd transmission
AXN 9.5 heavy duty axle
Z82 HD trailering, locking rear diff and heavy duty cooling
No recorded warranty claims
