NNBS 5.3 Injector Swap
Old Jun 10, 2010 | 10:47 AM
KHester84's Avatar
Default NNBS 5.3 Injector Swap
I'm thinking about getting a turbo kit for my '08 Z71 with the LY5 iron block 5.3 and am creating a parts list to get an idea of the total cost of the project and I'm going to swap the stock injectors to some 60lb injectors. I read somewhere that I need to use LS3 injectors for a direct swap with no spacers needed for the fuel rail or modifications to the injector harness. Is this correct? What kind is recommended?
I wish there was a write up to the different engine models and injectors that will work with each combo, along with the necessary modifications needed if you use a different style injector. I've looked for one here and on ls1tech but didn't really see anthing. I maybe overlooked it haha.
Thanks,
Keith
Old Jun 10, 2010 | 10:37 PM
Three6GMC's Avatar
Yeah im doing the same thing on my 09, so far I have most of the parts minus the fuel system. From what iv read and reaserched our injectors use the UScar connectors and are the ls2 type now im not 100% sure on this but ill be ordering some 57lb FAST injectors from speed engineering soon so ill get back to you on that..... I have spent maybe 1500 so far on misc. parts and maybe need another 1000 and I should be done with the way i want it. Are you going top mount or rear?
Old Jun 10, 2010 | 10:40 PM
Three6GMC's Avatar
These are the injectors im going with.....
FAST Fuel Injectors 57lb.
30572-8 $364.32
The FAST™ Precision-Flow™ Fuel Injectors for GM Gen IV engines are the highest flowing injectors available and are
uniquely designed for direct installation into LS2 and LS7/L76/L92-style engines. Available in two different height configurations
and a wide range of flow rates, the new Precision-Flow™ Fuel Injectors are correctly sized (shorter than the
common LS1/LS6 injectors) and feature the right EV6/UScar connector, enabling hassle-free plug-in operation. In addition,
the high-impedance, high-flow FAST™ injectors meet/exceed all factory durability standards and quality tolerances.
Specifics:
• Feature highest flow rate of any injector for '05-'08 GM LS2/LS7/L76/L92 engines; available in singles, -4, -6, -8
• A simple drop-in installation available in flow rates up to 57 lb/hr (LS2–type) & 65 lb/hr (LS7/L76/L92-type)
• Available in LS2 & LS7/L76/L92 “shorty” configurations; both styles feature proper OEM EV6/UScar connectors
• These high-impedance Precision-Flow™ Injectors meet/exceed all factory durability standards & tolerances
DESCRIPTION PART NO.
LS2-Type, EV6/UScar, 33lb/hr, Stock LS2 30332-8
LS2-Type, EV6/UScar, 46lb/hr 30462-8
LS2-Type, EV6/UScar, 57lb/hr 30572-8
L76/L92/LS7-Type Short, EV6/UScar, 39 lb/hr, Stock LS7 30397-8
L76/L92/LS7-Type Short, EV6/UScar, 50 lb/hr 30507-8
L76/L92/LS7-Type Short, EV6/UScar, 65 lb/hr 30657-8
Old Jun 11, 2010 | 06:09 AM
Preston129's Avatar
Three6GMC, do you know what stock flow rating is for the 5.3s? says 33-lb/hr for the stock LS2, wonder if ours is the same.
Old Jun 11, 2010 | 06:58 AM
Three6GMC's Avatar
my truck is the Flex Fuel so mine is a little higher then a normal 5.3 i think they are around 34lb for the other non Flex Fuel trucks they are 26lb from what iv read
Old Jun 12, 2010 | 09:44 AM
Preston129's Avatar
Are the injectors on our trucks tall or short style? I just checked and they look like the tall style. Which makes sense as the LS2s are tall.
Old Jun 12, 2010 | 09:42 PM
Three6GMC's Avatar
yeah well there considered the "short" style because the ls1/6 injectors are the tall ones and the l76/l92/ls7 are "shorty" style as they are the shortest injectors if that makes sense.....ours are in between from what i understood
Old Jun 14, 2010 | 09:47 AM
KHester84's Avatar
Good looking kit so far...looks like I'll be using those same injectors. I'll be going with a front mount, either MP 70mm or 76mm. I'm thinking the 70 would be sufficient for my initial power goals and weak 4L60e tranny. When I get bored I'll upgrade to a ball bearing 76 with a 4L80e.
What other fuel system upgrades are you doing? Tuning it yourself?
Thanks for the information about the injectors.
Old Jun 20, 2010 | 03:23 AM
Three6GMC's Avatar
for fuel for now just a walbro 255 intank and those injectors which should be fine for the 8lbs of boost i want to run, but later after i get a good built motor and turn up the boost i plan on going with dual intank walbro 255's -10AN fuel line to some Fast fuel rails same injectors or maybe bigger and convert to a return style fuel system with a A1000 Aeromotive boost referenced regulator. Its overkill even for my next setup cuz i only plan on maybe 15lbs max boost but rather have it and not need it then need it and not have it. oh and as for tuning I have a buddy down in the valley who tunes it for me with HP Tuners software and a Innovate wideband
Choda
Jan 22, 2026 02:03 PM
chopperloco
Jul 10, 2016 10:45 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
blackdc3
Jul 7, 2015 07:52 PM
