Help! Arp crank bolt problem!!!
Old Jul 28, 2012 | 05:31 PM
20002wdchevy's Avatar
14 Second Truck Club
Exclamation Help! Arp crank bolt problem!!!
So got my underdrive pulley on and went to tighen the new arp bolt and it got snug but wasent all the way seated. now it wont go in or come out any farther. my pulley isnt seated all the way and now I cant drive it in risk of destroying the front seal. #$%&!!!! its not cross threaded. any ideas??
Old Jul 28, 2012 | 05:49 PM
iamkeniff's Avatar
How did you tighten it? Any oil added to the threads? Arp lube? Did it thread by hand good or no? What UD pulley is it?
Old Jul 28, 2012 | 05:56 PM
Robert91RS's Avatar
Any chance you got the longer balancer bolt for LS7/9 cranks?
Old Jul 28, 2012 | 06:03 PM
chevrolade's Avatar
yea what brand pulley is it
Old Jul 28, 2012 | 06:20 PM
powerbond came in a kit from sdpc correct part number for truck application. I tightened it in by hand a fair bit before using my 1/2" impact.
Old Jul 28, 2012 | 06:23 PM
2000chevysilverado's Avatar
Is it same length as your old one, just a thought
Old Jul 28, 2012 | 06:27 PM
I didnt compare.... as I should have. ****
1Bear's Avatar
Ive seen this before when ordering a ARP crank bolt for a LS1 application and using it with a stock truck balancer. The bolt was slightly too long causing it to bottom out and galling up at the end of the bolt, basically friction welding the two together. In the gentlemans case, he too suffered from the pulley not being installed far enough and was throwing belts faster than he could install them. Due to being galled in place, the bolt snapped off in the end of the crank and the sad decision was made to replace the crankshaft in his 5.3L, as drilling out the extremely hard ARP bolt became futile. I hope for your sake you can get the bolt back out without it snapping off.
Old Jul 28, 2012 | 06:43 PM
iamkeniff's Avatar
How are you trying to take the bolt out? With the impact? Try a breaker bar and lock the flexplate in place
Old Jul 28, 2012 | 06:49 PM
I broke 2 3" 1/2" extentions trying the breaker bar method. it will move a little then stops
